Using Tuya integration with Tervix Pro Line ZigBee color thermostat. Several available features are not exposed in HA:
- Sensor selection (in/out/all modes)
- Window detection state and control
- Frost protection
- Temperature correction
- Humidity sensor
- Child lock
- Missing proper HVAC modes (shows heat_cool twice)
Product details:
- ID: 6kijc7nd
- Name: Thermostat Tervix Pro Line ZigBee color
These features are accessible via Tuya API as shown in diagnostic data.
"function": {
"switch": {
"type": "Boolean",
"value": {}
"mode": {
"type": "Enum",
"value": {
"range": [
"manual",
"program"
"window_check": {
"type": "Boolean",
"value": {}
"frost": {
"type": "Boolean",
"value": {}
"temp_set": {
"type": "Integer",
"value": {
"unit": "\u2103",
"min": 50,
"max": 950,
"scale": 1,
"step": 5
"upper_temp": {
"type": "Integer",
"value": {
"unit": "\u2103",
"min": 350,
"max": 950,
"scale": 1,
"step": 5
"temp_correction": {
"type": "Integer",
"value": {
"unit": "\u2103",
"min": -9,
"max": 9,
"scale": 0,
"step": 1
"factory_reset": {
"type": "Boolean",
"value": {}
"child_lock": {
"type": "Boolean",
"value": {}
"sensor_choose": {
"type": "Enum",
"value": {
"range": [
"in",
"out"
"status_range": {
"switch": {
"type": "Boolean",
"value": {}
"mode": {
"type": "Enum",
"value": {
"range": [
"manual",
"program"
"window_check": {
"type": "Boolean",
"value": {}
"frost": {
"type": "Boolean",
"value": {}
"temp_set": {
"type": "Integer",
"value": {
"unit": "\u2103",
"min": 50,
"max": 950,
"scale": 1,
"step": 5
"upper_temp": {
"type": "Integer",
"value": {
"unit": "\u2103",
"min": 350,
"max": 950,
"scale": 1,
"step": 5
"temp_current": {
"type": "Integer",
"value": {
"unit": "\u2103",
"min": 0,
"max": 995,
"scale": 1,
"step": 5
"window_state": {
"type": "Enum",
"value": {
"range": [
"close",
"open"
"type": "Integer",
"value": {
"unit": "\u2103",
"min": -9,
"max": 9,
"scale": 0,
"step": 1
"humidity": {
"type": "Integer",
"value": {
"unit": "%",
"min": 0,
"max": 100,
"scale": 0,
"step": 1
"factory_reset": {
"type": "Boolean",
"value": {}
"child_lock": {
"type": "Boolean",
"value": {}
"sensor_choose": {
"type": "Enum",
"value": {
"range": [
"in",
"out"
"status": {
"switch": true,
"mode": "manual",
"window_check": false,
"frost": false,
"temp_set": 215,
"upper_temp": 450,
"temp_current": 195,
"window_state": "close",
"temp_correction": -2,
"humidity": 23,
"factory_reset": false,
"child_lock": false,
"sensor_choose": "all"
Is there is any way to at least implement those via YAML configuration or pull from Tuya?
