The problem
BR 7-in-1 WLAN Wetterstation Anthrazit (fsea1lat3vuktbt6) works well in the Smart Life / Tuya app and through the Tuya developer platform, but is unsupported in the Tuya Home Assistant integration.
What version of Home Assistant Core has the issue?
core-2025.3.1
What was the last working version of Home Assistant Core?
No response
What type of installation are you running?
Home Assistant OS
Integration causing the issue
Tuya
Link to integration documentation on our website
Diagnostics information
"home_assistant": {
"installation_type": "Home Assistant OS",
"version": "2025.3.1",
"dev": false,
"hassio": true,
"virtualenv": false,
"python_version": "3.13.2",
"docker": true,
"arch": "x86_64",
"timezone": "Europe/Berlin",
"os_name": "Linux",
"os_version": "6.6.73-haos",
"supervisor": "2025.03.2",
"host_os": "Home Assistant OS 14.2",
"docker_version": "27.2.0",
"chassis": "vm",
"run_as_root": true
"custom_components": {
"landroid_cloud": {
"documentation": "https://github.com/MTrab/landroid_cloud/blob/7b03e3e18fafa390574f873866841d323f67ccd8/README.md",
"version": "5.1.0",
"requirements": [
"pyworxcloud==4.1.15"
"waste_collection_schedule": {
"documentation": "https://github.com/mampfes/hacs_waste_collection_schedule#readme",
"version": "2.7.0",
"requirements": [
"icalendar",
"icalevents>=0.1.26,!=0.1.28",
"beautifulsoup4",
"lxml",
"pycryptodome",
"pypdf"
"localtuya": {
"documentation": "https://github.com/rospogrigio/localtuya/",
"version": "5.2.3",
"requirements": []
"hacs": {
"documentation": "https://hacs.xyz/docs/use/",
"version": "2.0.5",
"requirements": [
"aiogithubapi>=22.10.1"
"skodaconnect": {
"documentation": "https://github.com/skodaconnect/homeassistant-skodaconnect/blob/68b5095e3dc7ce882e6e317eb47f28b4d4145bd2/README.md",
"version": "v1.2.13",
"requirements": [
"skodaconnect==1.3.11",
"homeassistant>=2024.4.0"
"dreo": {
"documentation": "https://github.com/jeffsteinbok/hass-dreo/blob/master/README.md",
"version": "1.0.0",
"requirements": [
"websockets"
"integration_manifest": {
"domain": "tuya",
"name": "Tuya",
"codeowners": [
"Tuya",
"zlinoliver"
"config_flow": true,
"dependencies": [
"ffmpeg"
"dhcp": [
"macaddress": "105A17*"
"macaddress": "10D561*"
"macaddress": "1869D8*"
"macaddress": "381F8D*"
"macaddress": "508A06*"
"macaddress": "68572D*"
"macaddress": "708976*"
"macaddress": "7CF666*"
"macaddress": "84E342*"
"macaddress": "D4A651*"
"macaddress": "D81F12*"
"documentation": "https://www.home-assistant.io/integrations/tuya",
"integration_type": "hub",
"iot_class": "cloud_push",
"loggers": [
"tuya_iot"
"requirements": [
"tuya-device-sharing-sdk==0.2.1"
"is_built_in": true,
"overwrites_built_in": false
"setup_times": {
"null": {
"setup": 4.9165915697813034e-05
"8693d24eb160adfed28234db6a9b9490": {
"wait_import_platforms": -0.14580788975581527,
"wait_base_component": -0.0013772272504866123,
"config_entry_setup": 2.008614895865321
"data": {
"endpoint": "https://apigw.tuyaeu.com",
"terminal_id": "1741540148825BB5Z1o",
"mqtt_connected": true,
"disabled_by": null,
"disabled_polling": false,
"id": "bf3a2e8b4f1643c712jhlc",
"name": "Wetterstation",
"category": "qxj",
"product_id": "fsea1lat3vuktbt6",
"product_name": "BR 7-in-1 WLAN Wetterstation Anthrazit",
"online": true,
"sub": false,
"time_zone": "+01:00",
"active_time": "2025-02-19T15:59:33+00:00",
"create_time": "2025-02-19T15:59:33+00:00",
"update_time": "2025-02-19T15:59:33+00:00",
"function": {
"temp_unit_convert": {
"type": "Enum",
"value": {
"range": [
"c",
"f"
"windspeed_unit_convert": {
"type": "Enum",
"value": {
"range": [
"mph"
"pressure_unit_convert": {
"type": "Enum",
"value": {
"range": [
"hpa",
"inhg",
"mmhg"
"rain_unit_convert": {
"type": "Enum",
"value": {
"range": [
"mm",
"inch"
"bright_unit_convert": {
"type": "Enum",
"value": {
"range": [
"lux",
"fc",
"wm2"
"status_range": {
"temp_current": {
"type": "Integer",
"value": {
"unit": "\u2103",
"min": -400,
"max": 600,
"scale": 1,
"step": 1
"humidity_value": {
"type": "Integer",
"value": {
"unit": "%",
"min": 0,
"max": 100,
"scale": 0,
"step": 1
"battery_state": {
"type": "Enum",
"value": {
"range": [
"low",
"high"
"type": "Enum",
"value": {
"range": [
"c",
"f"
"type": "Enum",
"value": {
"range": [
"mph"
"type": "Enum",
"value": {
"range": [
"hpa",
"inhg",
"mmhg"
"type": "Enum",
"value": {
"range": [
"mm",
"inch"
"type": "Enum",
"value": {
"range": [
"lux",
"fc",
"wm2"
"fault_type": {
"type": "Enum",
"value": {
"range": [
"normal",
"ch1_offline",
"ch2_offline",
"ch3_offline",
"offline"
"battery_status": {
"type": "Enum",
"value": {
"range": [
"low",
"high"
"battery_state_1": {
"type": "Enum",
"value": {
"range": [
"low",
"high"
"battery_state_2": {
"type": "Enum",
"value": {
"range": [
"low",
"high"
"battery_state_3": {
"type": "Enum",
"value": {
"range": [
"low",
"high"
"temp_current_external": {
"type": "Integer",
"value": {
"unit": "\u2103",
"min": -400,
"max": 600,
"scale": 1,
"step": 1
"humidity_outdoor": {
"type": "Integer",
"value": {
"unit": "%",
"min": 0,
"max": 100,
"scale": 0,
"step": 1
"temp_current_external_1": {
"type": "Integer",
"value": {
"unit": "\u2103",
"min": -400,
"max": 600,
"scale": 1,
"step": 1
"humidity_outdoor_1": {
"type": "Integer",
"value": {
"unit": "%",
"min": 0,
"max": 100,
"scale": 0,
"step": 1
"temp_current_external_2": {
"type": "Integer",
"value": {
"unit": "\u2103",
"min": -400,
"max": 600,
"scale": 1,
"step": 1
"humidity_outdoor_2": {
"type": "Integer",
"value": {
"unit": "%",
"min": 0,
"max": 100,
"scale": 0,
"step": 1
"temp_current_external_3": {
"type": "Integer",
"value": {
"unit": "\u2103",
"min": -400,
"max": 600,
"scale": 1,
"step": 1
"humidity_outdoor_3": {
"type": "Integer",
"value": {
"unit": "%",
"min": 0,
"max": 100,
"scale": 0,
"step": 1
"atmospheric_pressture": {
"type": "Integer",
"value": {
"unit": "hPa",
"min": 3000,
"max": 12000,
"scale": 1,
"step": 1
"pressure_drop": {
"type": "Integer",
"value": {
"unit": "hPa",
"min": 0,
"max": 15,
"scale": 0,
"step": 1
"windspeed_avg": {
"type": "Integer",
"value": {
"unit": "m/s",
"min": 0,
"max": 700,
"scale": 1,
"step": 1
"windspeed_gust": {
"type": "Integer",
"value": {
"unit": "m/s",
"min": 0,
"max": 700,
"scale": 1,
"step": 1
"wind_direct": {
"type": "Enum",
"value": {
"range": [
"north",
"north_north_east",
"north_east",
"east_north_east",
"east",
"east_south_east",
"south_east",
"south_south_east",
"south",
"south_south_west",
"south_west",
"west_south_west",
"west",
"west_north_west",
"north_west",
"north_north_west"
"rain_24h": {
"type": "Integer",
"value": {
"unit": "mm",
"min": 0,
"max": 1000000,
"scale": 3,
"step": 1
"rain_rate": {
"type": "Integer",
"value": {
"unit": "mm",
"min": 0,
"max": 999999,
"scale": 3,
"step": 1
"uv_index": {
"type": "Integer",
"value": {
"unit": "",
"min": 0,
"max": 180,
"scale": 1,
"step": 1
"bright_value": {
"type": "Integer",
"value": {
"unit": "lux",
"min": 0,
"max": 238000,
"scale": 0,
"step": 100
"dew_point_temp": {
"type": "Integer",
"value": {
"unit": "\u2103",
"min": -400,
"max": 800,
"scale": 1,
"step": 1
"feellike_temp": {
"type": "Integer",
"value": {
"unit": "\u2103",
"min": -650,
"max": 500,
"scale": 1,
"step": 1
"heat_index": {
"type": "Integer",
"value": {
"unit": "\u2103",
"min": 260,
"max": 500,
"scale": 1,
"step": 1
"windchill_index": {
"type": "Integer",
"value": {
"unit": "\u2103",
"min": -650,
"max": 600,
"scale": 1,
"step": 1
"com_index": {
"type": "Enum",
"value": {
"range": [
"moist",
"dry",
"comfortable"
"status": {
"temp_current": 123,
"humidity_value": 61,
"battery_state": "high",
"temp_unit_convert": "c",
"windspeed_unit_convert": "km_h",
"pressure_unit_convert": "hpa",
"rain_unit_convert": "mm",
"bright_unit_convert": "lux",
"fault_type": "normal",
"battery_status": "high",
"battery_state_1": "low",
"battery_state_2": "low",
"battery_state_3": "low",
"temp_current_external": 95,
"humidity_outdoor": 66,
"temp_current_external_1": -400,
"humidity_outdoor_1": 0,
"temp_current_external_2": -400,
"humidity_outdoor_2": 0,
"temp_current_external_3": -400,
"humidity_outdoor_3": 0,
"atmospheric_pressture": 9660,
"pressure_drop": 0,
"windspeed_avg": 0,
"windspeed_gust": 0,
"wind_direct": "north_west",
"rain_24h": 0,
"rain_rate": 0,
"uv_index": 0,
"bright_value": 41,
"dew_point_temp": 34,
"feellike_temp": 95,
"heat_index": 260,
"windchill_index": 95,
"com_index": "moist"
"home_assistant": {
"name_by_user": null,
"disabled": false,
"entities": []
"set_up": false,
"support_local": true
Example YAML snippet
Anything in the logs that might be useful for us?
Additional information
No response
