Tuya IOT Core Reminder / Multi purposes reminder
:compass: Tuya IOT Core Reminder Add-on
Home Assistant
Supervisor API
Python
A lightweight Home Assistant add-on to remind about Tuya IoT Core subscription expiry.
Sends mobile push notifications directly via the Home Assistant Supervisor API — no cloud, no credentials.
This project was created for self-improvement and exploring the Homeassistant API for sending push notifications to mobile devices. It can be used as a reminder for specific dates or as part of a larger project responsible for sending push notifications.
:sparkles: Features
  • :alarm_clock: Notifies about subscription expiry (30, 14, 7, 3, and 1 day before expiry)
  • :iphone: Automatically lists available notify.mobile_app_* services in the log
  • :mag: Debug mode for detailed network and scheduling output
  • :lock: Uses built-in Supervisor authentication (SUPERVISOR_TOKEN)
:gear: Installation
  1. In Home Assistant:
    • Go to Settings → Add-ons → Repositories
    • Click Add repository and paste this repo URL
    • Install Tuya IOT Core Reminder from your repository list
  2. Configure your options in the add-on configuration UI
:jigsaw: Configuration Options
Option Type Default Description
expiry_date string "31/12/2030" Subscription expiry date (format depends on date_format).
expiry_time string "12:00" Time of the day for expiry (24h format, UTC).
date_format string "auto" Date format: "auto", "us", "eu", "iso".
notify_service string "notify.mobile_app_myphone" Target notification service (notify.mobile_app_*).
push_count int 1 How many times to repeat the push notification.
push_interval_min int 60 Interval between repeated notifications (in minutes).
debug bool false Enable debug logging (detailed network and scheduling info).
:rocket: Usage
When the add-on starts, the log will show:
✅ Loaded configuration values
📅 Remaining days until subscription expiry
📱 List of available mobile apps (copy one into notify_service)
Notifications are sent automatically according to the schedule:
advance_days = [30, 14, 7, 3, 1]
:receipt: Example Log Output
  INFO: Loaded config: expiry=2025-12-31 12:00:00+00:00, notify=notify.mobile_app_myphone, debug=False
  INFO: Available mobile apps:
  INFO:   notify.mobile_app_sm_a715f
  INFO:   notify.mobile_app_redmi_s2
  INFO:   notify.mobile_app_sm_a505fn
  INFO: Initialized NotificationScheduler using Supervisor API authentication.
  INFO: Tuya IOT Core expires in 85 days
  INFO: Notification sent successfully (1/1)
To select a mobile app, copy one of the notify.mobile_app_* services from the log and paste it into the notify_service option.
:memo: Notes
Mobile app services are automatically detected and listed in the log.
Debug logging can be enabled via the debug option in the configuration.
The add-on uses only Supervisor-level access — safe for both Home Assistant OS and Core installations.
Notifications repeat automatically if configured with push_count > 1.
:bulb: Tips
Combine this add-on with Home Assistant Automations or a dashboard card to visualize your Tuya IoT Core expiry.
Works offline — no external cloud connections.
