I have a Tuya light connected through home assistant. It supports warm white and the rgb spectrum. When cinnvted through the Tuya integration on home assistant. The light’s warm white feature does not work as warm white on home assistant turns the light in the room to a led white (like the blueish light you get from a led light strip) is there any way to configure this to use the warm white feature? Thanks in advance
Any (formatted) code or integrations we should examine?
