Hi I have several Tuya switches and lights that are showing up in the entity registry.
I added 2 more and can’t get them to show up in entity registry.
In system options Enable newly added entities. is set to on.
Seems like it is not updating. What else can I look at?
Thanks for the reply
Actually yes. Even removed them from Tuya and reset and still nothing.
I just installed 2 different brands I purchased at Costco today also using Tuya and they both showed up automatically.
I can just replace the 2 that don’t work well but actually like the look and easabillity of use compared to others. wierd that all are found by HA except these 2. Even have 2 switches from Moes without dimmers and work fine…
Has anyone worked out which platform to use when the app used to register the lights is “PlusMinus” (this is the one that is recommended to replace the Lumiman app).
I previously registered them using the Tuya app - but the lights do not appear in HA so I reregistered them in PlusMinus.
I tried the 3 listed in the Tuya component page and also tried inventing a few (like plusminus and plus_minus) but they all fail. The ones with invented platform names return an error from Tuya saying that the platform is invalid which is fair enough.
Replying to myself … I gave up on getting the Lumiman/PlusMinus RGBW lamp working with the Tuya integration. I considered going down the LocalTuya route but decided to take another look at Tasmota.
It worked.
So have now installed Mosquitto on same box as HA and it is working well.
Also enabled the Hue emulation in Tasmota and Alexa discovered it and gives me On/Off and colour setting.
However, you are replying to an old post of mine and since then the Tuya firmware that ships with the newer bulbs cannot be hijacked in the same way.
I haven’t researched recently to see if someone has found a software-only way around it.
