Hello Brains Trust…
Everything was working just fine… until I installed latest update.
Now I have a problem I can’t quite figure out.
I had to re-setup any devices uses Tuya Local as they stopped working after the update. All worked fine, until I needed to do a restart, then they all fell offline. To fix them all I had to do was disable them and re-enable and they popped back up.
Then again, restarted the system and they went offline again! Same solution to bring them back of disabling then enabling them. But I’m at a loss as to what might be causing this or how to remedy?
Any advice welcome?
