Tuya local - need to be fixed IP address?
As above, I am using Tuya Local, and things keep dropping off… Have to click Setup > Integrations > Tuya Local > “device” > reload… Sometimes it works, sometimes it doesn’t…
Would this be because IP addresses are changing? Is there any other way to ‘fix’ this, without fixing IP addresses?
Your router should have the option to set a DHCP Reservation for any connected device - that would be the first thing I’d try… In an abundance of caution (and because it’s so easy to do), I have DHCP reservations set for all of our routinely-connected-to-our-network devices (smart-home and otherwise).
Thanks,
Used to fix IP addresses, but thought that was basically unnecessary, these days?
Seems it does cause issues, though…
Thanks for your reply.
