I have this weird issue with the tuya smart RTV’s TS0601. Immediately after I’ve joined them with Zigbee2MQTT it becomes unavailable. Interview is completed but the “Last seen” status is N/A
See the logs below for more information.
What have I tried already?
Deleted the device from the Zigbee2MQTT dashboard and joined it again → same result
Changed the RTV (I have several) → same result
I am quite new to home assistant and this is my first zigbee2mqtt project. Most of the logging I don’t understand yet. Hopefully someone can point me to the right direction!
''Info 2023-02-22 21:23:04MQTT publish: topic ‘zigbee2mqtt/bridge/response/device/configure’, payload ‘{“data”:{“id”:“0x9035eafffe670ef5”},“error”:“Device ‘0x9035eafffe670ef5’ cannot be configured”,“status”:“error”,“transaction”:“lik75-8”}’
Info 2023-02-22 21:30:54MQTT publish: topic ‘zigbee2mqtt/0x9035eafffe670ef5’, payload ‘{“auto_lock”:“AUTO”,“away_mode”:“OFF”,“away_preset_days”:1,“away_preset_temperature”:15,“battery_low”:false,“boost_time”:300,“child_lock”:“UNLOCK”,“comfort_temperature”:20,“current_heating_setpoint”:19,“eco_temperature”:15,“force”:“normal”,“holidays”:[{“hour”:6,“minute”:0,“temperature”:20},{“hour”:8,“minute”:0,“temperature”:15},{“hour”:11,“minute”:30,“temperature”:15},{“hour”:12,“minute”:30,“temperature”:15},{“hour”:17,“minute”:30,“temperature”:20},{“hour”:22,“minute”:0,“temperature”:15}],“holidays_schedule”:“06:00/20°C 08:00/15°C 11:30/15°C 12:30/15°C 17:30/20°C 22:00/15°C”,“linkquality”:111,“local_temperature”:21,“local_temperature_calibration”:-1,“max_temperature”:35,“min_temperature”:5,“position”:0,“preset”:“complex”,“programming_mode”:null,“running_state”:“idle”,“system_mode”:“auto”,“update”:{“installed_version”:-1,“latest_version”:-1,“state”:null},“update_available”:null,“valve_detection”:null,“week”:“5+2”,“window_detection”:“OFF”,“window_detection_params”:{“minutes”:10,“temperature”:5},“window_open”:false,“workdays”:[{“hour”:6,“minute”:0,“temperature”:20},{“hour”:8,“minute”:0,“temperature”:15},{“hour”:11,“minute”:30,“temperature”:15},{“hour”:12,“minute”:30,“temperature”:15},{“hour”:17,“minute”:30,“temperature”:20},{“hour”:22,“minute”:0,“temperature”:15}],“workdays_schedule”:“06:00/20°C 08:00/15°C 11:30/15°C 12:30/15°C 17:30/20°C 22:00/15°C”}’
Info 2023-02-22 21:31:26Removing device ‘0x9035eafffe670ef5’ (block: false, force: true)
Info 2023-02-22 21:31:26MQTT publish: topic ‘homeassistant/lock/0x9035eafffe670ef5/child_lock/config’, payload ‘null’
Info 2023-02-22 21:31:26MQTT publish: topic ‘homeassistant/switch/0x9035eafffe670ef5/window_detection/config’, payload ‘null’
Info 2023-02-22 21:31:26MQTT publish: topic ‘homeassistant/binary_sensor/0x9035eafffe670ef5/window_open/config’, payload ‘null’
Info 2023-02-22 21:31:26MQTT publish: topic ‘homeassistant/binary_sensor/0x9035eafffe670ef5/battery_low/config’, payload ‘null’
Info 2023-02-22 21:31:26MQTT publish: topic ‘homeassistant/switch/0x9035eafffe670ef5/valve_detection/config’, payload ‘null’
Info 2023-02-22 21:31:26MQTT publish: topic ‘homeassistant/sensor/0x9035eafffe670ef5/position/config’, payload ‘null’
Info 2023-02-22 21:31:26MQTT publish: topic ‘homeassistant/number/0x9035eafffe670ef5/local_temperature_calibration/config’, payload ‘null’
Info 2023-02-22 21:31:26MQTT publish: topic ‘homeassistant/climate/0x9035eafffe670ef5/climate/config’, payload ‘null’
Info 2023-02-22 21:31:26MQTT publish: topic ‘homeassistant/switch/0x9035eafffe670ef5/auto_lock/config’, payload ‘null’
Info 2023-02-22 21:31:26MQTT publish: topic ‘homeassistant/switch/0x9035eafffe670ef5/away_mode/config’, payload ‘null’
Info 2023-02-22 21:31:26MQTT publish: topic ‘homeassistant/sensor/0x9035eafffe670ef5/away_preset_days/config’, payload ‘null’
Info 2023-02-22 21:31:26MQTT publish: topic ‘homeassistant/number/0x9035eafffe670ef5/away_preset_days/config’, payload ‘null’
Info 2023-02-22 21:31:26MQTT publish: topic ‘homeassistant/sensor/0x9035eafffe670ef5/boost_time/config’, payload ‘null’
Info 2023-02-22 21:31:26MQTT publish: topic ‘homeassistant/number/0x9035eafffe670ef5/boost_time/config’, payload ‘null’
Info 2023-02-22 21:31:26MQTT publish: topic ‘homeassistant/sensor/0x9035eafffe670ef5/comfort_temperature/config’, payload ‘null’
Info 2023-02-22 21:31:26MQTT publish: topic ‘homeassistant/number/0x9035eafffe670ef5/comfort_temperature/config’, payload ‘null’
Info 2023-02-22 21:31:26MQTT publish: topic ‘homeassistant/sensor/0x9035eafffe670ef5/eco_temperature/config’, payload ‘null’
Info 2023-02-22 21:31:26MQTT publish: topic ‘homeassistant/number/0x9035eafffe670ef5/eco_temperature/config’, payload ‘null’
Info 2023-02-22 21:31:26MQTT publish: topic ‘homeassistant/sensor/0x9035eafffe670ef5/force/config’, payload ‘null’
Info 2023-02-22 21:31:26MQTT publish: topic ‘homeassistant/select/0x9035eafffe670ef5/force/config’, payload ‘null’
Info 2023-02-22 21:31:26MQTT publish: topic ‘homeassistant/sensor/0x9035eafffe670ef5/max_temperature/config’, payload ‘null’
Info 2023-02-22 21:31:26MQTT publish: topic ‘homeassistant/number/0x9035eafffe670ef5/max_temperature/config’, payload ‘null’
Info 2023-02-22 21:31:26MQTT publish: topic ‘homeassistant/sensor/0x9035eafffe670ef5/min_temperature/config’, payload ‘null’
Info 2023-02-22 21:31:26MQTT publish: topic ‘homeassistant/number/0x9035eafffe670ef5/min_temperature/config’, payload ‘null’
Info 2023-02-22 21:31:26MQTT publish: topic ‘homeassistant/sensor/0x9035eafffe670ef5/away_preset_temperature/config’, payload ‘null’
Info 2023-02-22 21:31:26MQTT publish: topic ‘homeassistant/number/0x9035eafffe670ef5/away_preset_temperature/config’, payload ‘null’
Info 2023-02-22 21:31:26MQTT publish: topic ‘homeassistant/sensor/0x9035eafffe670ef5/programming_mode/config’, payload ‘null’
Info 2023-02-22 21:31:26MQTT publish: topic ‘homeassistant/sensor/0x9035eafffe670ef5/linkquality/config’, payload ‘null’
Info 2023-02-22 21:31:26MQTT publish: topic ‘homeassistant/sensor/0x9035eafffe670ef5/update_state/config’, payload ‘null’
Info 2023-02-22 21:31:26MQTT publish: topic ‘homeassistant/binary_sensor/0x9035eafffe670ef5/update_available/config’, payload ‘null’
Info 2023-02-22 21:31:26MQTT publish: topic ‘homeassistant/update/0x9035eafffe670ef5/update/config’, payload ‘null’
Info 2023-02-22 21:31:26MQTT publish: topic ‘zigbee2mqtt/0x9035eafffe670ef5’, payload ‘’
Info 2023-02-22 21:31:26Successfully removed device ‘0x9035eafffe670ef5’ (block: false, force: true)
Info 2023-02-22 21:31:26MQTT publish: topic ‘zigbee2mqtt/bridge/response/device/remove’, payload ‘{“data”:{“block”:false,“force”:true,“id”:“0x9035eafffe670ef5”},“status”:“ok”,“transaction”:“lik75-9”}’
Info 2023-02-22 21:39:19Zigbee: allowing new devices to join.
Info 2023-02-22 21:39:20MQTT publish: topic ‘zigbee2mqtt/bridge/response/permit_join’, payload ‘{“data”:{“time”:254,“value”:true},“status”:“ok”,“transaction”:“lik75-10”}’
Info 2023-02-22 21:39:23Device ‘0x84ba20fffe7dafd4’ joined
Info 2023-02-22 21:39:23MQTT publish: topic ‘zigbee2mqtt/bridge/event’, payload ‘{“data”:{“friendly_name”:“0x84ba20fffe7dafd4”,“ieee_address”:“0x84ba20fffe7dafd4”},“type”:“device_joined”}’
Info 2023-02-22 21:39:23Starting interview of ‘0x84ba20fffe7dafd4’
Info 2023-02-22 21:39:23MQTT publish: topic ‘zigbee2mqtt/bridge/event’, payload ‘{“data”:{“friendly_name”:“0x84ba20fffe7dafd4”,“ieee_address”:“0x84ba20fffe7dafd4”,“status”:“started”},“type”:“device_interview”}’
Info 2023-02-22 21:39:23MQTT publish: topic ‘zigbee2mqtt/bridge/event’, payload ‘{“data”:{“friendly_name”:“0x84ba20fffe7dafd4”,“ieee_address”:“0x84ba20fffe7dafd4”},“type”:“device_announce”}’
Info 2023-02-22 21:39:25Successfully interviewed ‘0x84ba20fffe7dafd4’, device has successfully been paired
Info 2023-02-22 21:39:25Device ‘0x84ba20fffe7dafd4’ is supported, identified as: TuYa Radiator valve with thermostat (TS0601_thermostat)
Info 2023-02-22 21:39:25MQTT publish: topic ‘zigbee2mqtt/bridge/event’, payload ‘{“data”:{“definition”:{“description”:“Radiator valve with thermostat”,“exposes”:[{“features”:[{“access”:3,“description”:“Enables/disables physical input on the device”,“name”:“state”,“property”:“child_lock”,“type”:“binary”,“value_off”:“UNLOCK”,“value_on”:“LOCK”}],“type”:“lock”},{“features”:[{“access”:3,“description”:“Enables/disables window detection on the device”,“name”:“state”,“property”:“window_detection”,“type”:“binary”,“value_off”:“OFF”,“value_on”:“ON”,“value_toggle”:“TOGGLE”}],“type”:“switch”},{“access”:1,“description”:“Window open?”,“name”:“window_open”,“property”:“window_open”,“type”:“binary”},{“access”:1,“description”:“Indicates if the battery of this device is almost empty”,“name”:“battery_low”,“property”:“battery_low”,“type”:“binary”,“value_off”:false,“value_on”:true},{“features”:[{“access”:3,“name”:“state”,“property”:“valve_detection”,“type”:“binary”,“value_off”:“OFF”,“value_on”:“ON”,“value_toggle”:“TOGGLE”}],“type”:“switch”},{“access”:1,“description”:“Position”,“name”:“position”,“property”:“position”,“type”:“numeric”,“unit”:"%"},{“features”:[{“access”:3,“description”:“Temperature setpoint”,“name”:“current_heating_setpoint”,“property”:“current_heating_setpoint”,“type”:“numeric”,“unit”:“°C”,“value_max”:35,“value_min”:5,“value_step”:0.5},{“access”:1,“description”:“Current temperature measured on the device”,“name”:“local_temperature”,“property”:“local_temperature”,“type”:“numeric”,“unit”:“°C”},{“access”:3,“description”:“Mode of this device, in the heat
mode the TS0601 will remain continuously heating, i.e. it does not regulate to the desired temperature. If you want TRV to properly regulate the temperature you need to use mode auto
instead setting the desired temperature.”,“name”:“system_mode”,“property”:“system_mode”,“type”:“enum”,“values”:[“heat”,“auto”,“off”]},{“access”:3,“description”:“Offset to be used in the local_temperature”,“name”:“local_temperature_calibration”,“property”:“local_temperature_calibration”,“type”:“numeric”,“unit”:“°C”,“value_max”:9,“value_min”:-9,“value_step”:1},{“access”:3,“description”:“Mode of this device (similar to system_mode)”,“name”:“preset”,“property”:“preset”,“type”:“enum”,“values”:[“schedule”,“manual”,“boost”,“complex”,“comfort”,“eco”,“away”]},{“access”:1,“description”:“The current running state”,“name”:“running_state”,“property”:“running_state”,“type”:“enum”,“values”:[“idle”,“heat”]}],“type”:“climate”},{“features”:[{“access”:3,“description”:“Enable/disable auto lock”,“name”:“state”,“property”:“auto_lock”,“type”:“binary”,“value_off”:“MANUAL”,“value_on”:“AUTO”}],“type”:“switch”},{“features”:[{“access”:3,“description”:“Enable/disable away mode”,“name”:“state”,“property”:“away_mode”,“type”:“binary”,“value_off”:“OFF”,“value_on”:“ON”}],“type”:“switch”},{“access”:3,“description”:“Away preset days”,“name”:“away_preset_days”,“property”:“away_preset_days”,“type”:“numeric”,“value_max”:100,“value_min”:0},{“access”:3,“description”:“Boost time”,“name”:“boost_time”,“property”:“boost_time”,“type”:“numeric”,“unit”:“s”,“value_max”:900,“value_min”:0},{“access”:3,“description”:“Comfort temperature”,“name”:“comfort_temperature”,“property”:“comfort_temperature”,“type”:“numeric”,“unit”:“°C”,“value_max”:30,“value_min”:0},{“access”:3,“description”:“Eco temperature”,“name”:“eco_temperature”,“property”:“eco_temperature”,“type”:“numeric”,“unit”:“°C”,“value_max”:35,“value_min”:0},{“access”:3,“description”:“Force the valve position”,“name”:“force”,“property”:“force”,“type”:“enum”,“values”:[“normal”,“open”,“close”]},{“access”:3,“description”:“Maximum temperature”,“name”:“max_temperature”,“property”:“max_temperature”,“type”:“numeric”,“unit”:“°C”,“value_max”:35,“value_min”:15},{“access”:3,“description”:“Minimum temperature”,“name”:“min_temperature”,“property”:“min_temperature”,“type”:“numeric”,“unit”:“°C”,“value_max”:15,“value_min”:1},{“access”:3,“description”:“Away preset temperature”,“name”:“away_preset_temperature”,“property”:“away_preset_temperature”,“type”:“numeric”,“unit”:“°C”,“value_max”:35,“value_min”:-10},{“access”:1,“description”:“Schedule MODE - In this mode, the device executes a preset week programming temperature time and temperature.”,“features”:[{“access”:3,“description”:“Week format user for schedule”,“name”:“week”,“property”:“week”,“type”:“enum”,“values”:[“5+2”,“6+1”,“7”]},{“access”:3,“name”:“workdays_schedule”,“property”:“workdays_schedule”,“type”:“text”},{“access”:3,“name”:“holidays_schedule”,“property”:“holidays_schedule”,“type”:“text”}],“name”:“programming_mode”,“property”:“programming_mode”,“type”:“composite”},{“access”:1,“description”:“Link quality (signal strength)”,“name”:“linkquality”,“property”:“linkquality”,“type”:“numeric”,“unit”:“lqi”,“value_max”:255,“value_min”:0}],“model”:“TS0601_thermostat”,“options”:[],“supports_ota”:true,“vendor”:“TuYa”},“friendly_name”:“0x84ba20fffe7dafd4”,“ieee_address”:“0x84ba20fffe7dafd4”,“status”:“successful”,“supported”:true},“type”:“device_interview”}’
Info 2023-02-22 21:39:25MQTT publish: topic ‘homeassistant/lock/0x84ba20fffe7dafd4/child_lock/config’, payload ‘{“availability”:[{“topic”:“zigbee2mqtt/bridge/state”,“value_template”:"{{ value_json.state }}"}],“command_topic”:“zigbee2mqtt/0x84ba20fffe7dafd4/set/child_lock”,“device”:{“identifiers”:[“zigbee2mqtt_0x84ba20fffe7dafd4”],“manufacturer”:“TuYa”,“model”:“Radiator valve with thermostat (TS0601_thermostat)”,“name”:“0x84ba20fffe7dafd4”},“name”:“0x84ba20fffe7dafd4 child lock”,“payload_lock”:“LOCK”,“payload_unlock”:“UNLOCK”,“state_locked”:“LOCK”,“state_topic”:“zigbee2mqtt/0x84ba20fffe7dafd4”,“state_unlocked”:“UNLOCK”,“unique_id”:“0x84ba20fffe7dafd4_child_lock_zigbee2mqtt”,“value_template”:"{{ value_json.child_lock }}"}’
Info 2023-02-22 21:39:25MQTT publish: topic ‘homeassistant/switch/0x84ba20fffe7dafd4/window_detection/config’, payload ‘{“availability”:[{“topic”:“zigbee2mqtt/bridge/state”,“value_template”:"{{ value_json.state }}"}],“command_topic”:“zigbee2mqtt/0x84ba20fffe7dafd4/set/window_detection”,“device”:{“identifiers”:[“zigbee2mqtt_0x84ba20fffe7dafd4”],“manufacturer”:“TuYa”,“model”:“Radiator valve with thermostat (TS0601_thermostat)”,“name”:“0x84ba20fffe7dafd4”},“icon”:“mdi:window-open-variant”,“name”:“0x84ba20fffe7dafd4 window detection”,“payload_off”:“OFF”,“payload_on”:“ON”,“state_off”:“OFF”,“state_on”:“ON”,“state_topic”:“zigbee2mqtt/0x84ba20fffe7dafd4”,“unique_id”:“0x84ba20fffe7dafd4_window_detection_zigbee2mqtt”,“value_template”:"{{ value_json.window_detection }}"}’
Info 2023-02-22 21:39:25MQTT publish: topic ‘homeassistant/binary_sensor/0x84ba20fffe7dafd4/window_open/config’, payload ‘{“availability”:[{“topic”:“zigbee2mqtt/bridge/state”,“value_template”:"{{ value_json.state }}"}],“device”:{“identifiers”:[“zigbee2mqtt_0x84ba20fffe7dafd4”],“manufacturer”:“TuYa”,“model”:“Radiator valve with thermostat (TS0601_thermostat)”,“name”:“0x84ba20fffe7dafd4”},“name”:“0x84ba20fffe7dafd4 window open”,“state_topic”:“zigbee2mqtt/0x84ba20fffe7dafd4”,“unique_id”:“0x84ba20fffe7dafd4_window_open_zigbee2mqtt”,“value_template”:"{{ value_json.window_open }}"}’
Info 2023-02-22 21:39:25MQTT publish: topic ‘homeassistant/binary_sensor/0x84ba20fffe7dafd4/battery_low/config’, payload ‘{“availability”:[{“topic”:“zigbee2mqtt/bridge/state”,“value_template”:"{{ value_json.state }}"}],“device”:{“identifiers”:[“zigbee2mqtt_0x84ba20fffe7dafd4”],“manufacturer”:“TuYa”,“model”:“Radiator valve with thermostat (TS0601_thermostat)”,“name”:“0x84ba20fffe7dafd4”},“device_class”:“battery”,“entity_category”:“diagnostic”,“name”:“0x84ba20fffe7dafd4 battery low”,“payload_off”:false,“payload_on”:true,“state_topic”:“zigbee2mqtt/0x84ba20fffe7dafd4”,“unique_id”:“0x84ba20fffe7dafd4_battery_low_zigbee2mqtt”,“value_template”:"{{ value_json.battery_low }}"}’
Info 2023-02-22 21:39:25MQTT publish: topic ‘homeassistant/switch/0x84ba20fffe7dafd4/valve_detection/config’, payload ‘{“availability”:[{“topic”:“zigbee2mqtt/bridge/state”,“value_template”:"{{ value_json.state }}"}],“command_topic”:“zigbee2mqtt/0x84ba20fffe7dafd4/set/valve_detection”,“device”:{“identifiers”:[“zigbee2mqtt_0x84ba20fffe7dafd4”],“manufacturer”:“TuYa”,“model”:“Radiator valve with thermostat (TS0601_thermostat)”,“name”:“0x84ba20fffe7dafd4”},“name”:“0x84ba20fffe7dafd4 valve detection”,“payload_off”:“OFF”,“payload_on”:“ON”,“state_off”:“OFF”,“state_on”:“ON”,“state_topic”:“zigbee2mqtt/0x84ba20fffe7dafd4”,“unique_id”:“0x84ba20fffe7dafd4_valve_detection_zigbee2mqtt”,“value_template”:"{{ value_json.valve_detection }}"}’
Info 2023-02-22 21:39:25MQTT publish: topic ‘homeassistant/sensor/0x84ba20fffe7dafd4/position/config’, payload ‘{“availability”:[{“topic”:“zigbee2mqtt/bridge/state”,“value_template”:"{{ value_json.state }}"}],“device”:{“identifiers”:[“zigbee2mqtt_0x84ba20fffe7dafd4”],“manufacturer”:“TuYa”,“model”:“Radiator valve with thermostat (TS0601_thermostat)”,“name”:“0x84ba20fffe7dafd4”},“enabled_by_default”:true,“icon”:“mdi:valve”,“name”:“0x84ba20fffe7dafd4 position”,“state_class”:“measurement”,“state_topic”:“zigbee2mqtt/0x84ba20fffe7dafd4”,“unique_id”:“0x84ba20fffe7dafd4_position_zigbee2mqtt”,“unit_of_measurement”:"%",“value_template”:"{{ value_json.position }}"}’
Info 2023-02-22 21:39:25MQTT publish: topic ‘homeassistant/number/0x84ba20fffe7dafd4/local_temperature_calibration/config’, payload ‘{“availability”:[{“topic”:“zigbee2mqtt/bridge/state”,“value_template”:"{{ value_json.state }}"}],“command_topic”:“zigbee2mqtt/0x84ba20fffe7dafd4/set/local_temperature_calibration”,“device”:{“identifiers”:[“zigbee2mqtt_0x84ba20fffe7dafd4”],“manufacturer”:“TuYa”,“model”:“Radiator valve with thermostat (TS0601_thermostat)”,“name”:“0x84ba20fffe7dafd4”},“device_class”:“temperature”,“entity_category”:“config”,“icon”:“mdi:math-compass”,“max”:9,“min”:-9,“name”:“0x84ba20fffe7dafd4 local temperature calibration”,“state_topic”:“zigbee2mqtt/0x84ba20fffe7dafd4”,“step”:1,“unique_id”:“0x84ba20fffe7dafd4_local_temperature_calibration_zigbee2mqtt”,“unit_of_measurement”:“°C”,“value_template”:"{{ value_json.local_temperature_calibration }}"}’
Info 2023-02-22 21:39:25MQTT publish: topic ‘homeassistant/climate/0x84ba20fffe7dafd4/climate/config’, payload ‘{“action_template”:"{% set values = {None:None,‘idle’:‘off’,‘heat’:‘heating’,‘cool’:‘cooling’,‘fan_only’:‘fan’} %}{{ values[value_json.running_state] }}",“action_topic”:“zigbee2mqtt/0x84ba20fffe7dafd4”,“availability”:[{“topic”:“zigbee2mqtt/bridge/state”,“value_template”:"{{ value_json.state }}"}],“current_temperature_template”:"{{ value_json.local_temperature }}",“current_temperature_topic”:“zigbee2mqtt/0x84ba20fffe7dafd4”,“device”:{“identifiers”:[“zigbee2mqtt_0x84ba20fffe7dafd4”],“manufacturer”:“TuYa”,“model”:“Radiator valve with thermostat (TS0601_thermostat)”,“name”:“0x84ba20fffe7dafd4”},“max_temp”:“35”,“min_temp”:“5”,“mode_command_topic”:“zigbee2mqtt/0x84ba20fffe7dafd4/set/system_mode”,“mode_state_template”:"{{ value_json.system_mode }}",“mode_state_topic”:“zigbee2mqtt/0x84ba20fffe7dafd4”,“modes”:[“heat”,“auto”,“off”],“name”:“0x84ba20fffe7dafd4”,“preset_mode_command_topic”:“zigbee2mqtt/0x84ba20fffe7dafd4/set/preset”,“preset_mode_state_topic”:“zigbee2mqtt/0x84ba20fffe7dafd4”,“preset_mode_value_template”:"{{ value_json.preset }}",“preset_modes”:[“schedule”,“manual”,“boost”,“complex”,“comfort”,“eco”,“away”],“temp_step”:0.5,“temperature_command_topic”:“zigbee2mqtt/0x84ba20fffe7dafd4/set/current_heating_setpoint”,“temperature_state_template”:"{{ value_json.current_heating_setpoint }}",“temperature_state_topic”:“zigbee2mqtt/0x84ba20fffe7dafd4”,“temperature_unit”:“C”,“unique_id”:“0x84ba20fffe7dafd4_climate_zigbee2mqtt”}’
Info 2023-02-22 21:39:25MQTT publish: topic ‘homeassistant/switch/0x84ba20fffe7dafd4/auto_lock/config’, payload ‘{“availability”:[{“topic”:“zigbee2mqtt/bridge/state”,“value_template”:"{{ value_json.state }}"}],“command_topic”:“zigbee2mqtt/0x84ba20fffe7dafd4/set/auto_lock”,“device”:{“identifiers”:[“zigbee2mqtt_0x84ba20fffe7dafd4”],“manufacturer”:“TuYa”,“model”:“Radiator valve with thermostat (TS0601_thermostat)”,“name”:“0x84ba20fffe7dafd4”},“name”:“0x84ba20fffe7dafd4 auto lock”,“payload_off”:“MANUAL”,“payload_on”:“AUTO”,“state_off”:“MANUAL”,“state_on”:“AUTO”,“state_topic”:“zigbee2mqtt/0x84ba20fffe7dafd4”,“unique_id”:“0x84ba20fffe7dafd4_auto_lock_zigbee2mqtt”,“value_template”:"{{ value_json.auto_lock }}"}’
Info 2023-02-22 21:39:25MQTT publish: topic ‘homeassistant/switch/0x84ba20fffe7dafd4/away_mode/config’, payload ‘{“availability”:[{“topic”:“zigbee2mqtt/bridge/state”,“value_template”:"{{ value_json.state }}"}],“command_topic”:“zigbee2mqtt/0x84ba20fffe7dafd4/set/away_mode”,“device”:{“identifiers”:[“zigbee2mqtt_0x84ba20fffe7dafd4”],“manufacturer”:“TuYa”,“model”:“Radiator valve with thermostat (TS0601_thermostat)”,“name”:“0x84ba20fffe7dafd4”},“name”:“0x84ba20fffe7dafd4 away mode”,“payload_off”:“OFF”,“payload_on”:“ON”,“state_off”:“OFF”,“state_on”:“ON”,“state_topic”:“zigbee2mqtt/0x84ba20fffe7dafd4”,“unique_id”:“0x84ba20fffe7dafd4_away_mode_zigbee2mqtt”,“value_template”:"{{ value_json.away_mode }}"}’
Info 2023-02-22 21:39:25MQTT publish: topic ‘homeassistant/sensor/0x84ba20fffe7dafd4/away_preset_days/config’, payload ‘{“availability”:[{“topic”:“zigbee2mqtt/bridge/state”,“value_template”:"{{ value_json.state }}"}],“device”:{“identifiers”:[“zigbee2mqtt_0x84ba20fffe7dafd4”],“manufacturer”:“TuYa”,“model”:“Radiator valve with thermostat (TS0601_thermostat)”,“name”:“0x84ba20fffe7dafd4”},“enabled_by_default”:false,“entity_category”:“config”,“icon”:“mdi:timer”,“name”:“0x84ba20fffe7dafd4 away preset days”,“state_topic”:“zigbee2mqtt/0x84ba20fffe7dafd4”,“unique_id”:“0x84ba20fffe7dafd4_away_preset_days_zigbee2mqtt”,“value_template”:"{{ value_json.away_preset_days }}"}’
Info 2023-02-22 21:39:25MQTT publish: topic ‘homeassistant/number/0x84ba20fffe7dafd4/away_preset_days/config’, payload ‘{“availability”:[{“topic”:“zigbee2mqtt/bridge/state”,“value_template”:"{{ value_json.state }}"}],“command_topic”:“zigbee2mqtt/0x84ba20fffe7dafd4/set/away_preset_days”,“device”:{“identifiers”:[“zigbee2mqtt_0x84ba20fffe7dafd4”],“manufacturer”:“TuYa”,“model”:“Radiator valve with thermostat (TS0601_thermostat)”,“name”:“0x84ba20fffe7dafd4”},“entity_category”:“config”,“icon”:“mdi:timer”,“max”:100,“min”:0,“name”:“0x84ba20fffe7dafd4 away preset days”,“state_topic”:“zigbee2mqtt/0x84ba20fffe7dafd4”,“unique_id”:“0x84ba20fffe7dafd4_away_preset_days_zigbee2mqtt”,“value_template”:"{{ value_json.away_preset_days }}"}’
Info 2023-02-22 21:39:25MQTT publish: topic ‘homeassistant/sensor/0x84ba20fffe7dafd4/boost_time/config’, payload ‘{“availability”:[{“topic”:“zigbee2mqtt/bridge/state”,“value_template”:"{{ value_json.state }}"}],“device”:{“identifiers”:[“zigbee2mqtt_0x84ba20fffe7dafd4”],“manufacturer”:“TuYa”,“model”:“Radiator valve with thermostat (TS0601_thermostat)”,“name”:“0x84ba20fffe7dafd4”},“enabled_by_default”:false,“entity_category”:“config”,“icon”:“mdi:timer”,“name”:“0x84ba20fffe7dafd4 boost time”,“state_topic”:“zigbee2mqtt/0x84ba20fffe7dafd4”,“unique_id”:“0x84ba20fffe7dafd4_boost_time_zigbee2mqtt”,“unit_of_measurement”:“s”,“value_template”:"{{ value_json.boost_time }}"}’
Info 2023-02-22 21:39:25MQTT publish: topic ‘homeassistant/number/0x84ba20fffe7dafd4/boost_time/config’, payload ‘{“availability”:[{“topic”:“zigbee2mqtt/bridge/state”,“value_template”:"{{ value_json.state }}"}],“command_topic”:“zigbee2mqtt/0x84ba20fffe7dafd4/set/boost_time”,“device”:{“identifiers”:[“zigbee2mqtt_0x84ba20fffe7dafd4”],“manufacturer”:“TuYa”,“model”:“Radiator valve with thermostat (TS0601_thermostat)”,“name”:“0x84ba20fffe7dafd4”},“entity_category”:“config”,“icon”:“mdi:timer”,“max”:900,“min”:0,“name”:“0x84ba20fffe7dafd4 boost time”,“state_topic”:“zigbee2mqtt/0x84ba20fffe7dafd4”,“unique_id”:“0x84ba20fffe7dafd4_boost_time_zigbee2mqtt”,“unit_of_measurement”:“s”,“value_template”:"{{ value_json.boost_time }}"}’
Info 2023-02-22 21:39:25MQTT publish: topic ‘homeassistant/sensor/0x84ba20fffe7dafd4/comfort_temperature/config’, payload ‘{“availability”:[{“topic”:“zigbee2mqtt/bridge/state”,“value_template”:"{{ value_json.state }}"}],“device”:{“identifiers”:[“zigbee2mqtt_0x84ba20fffe7dafd4”],“manufacturer”:“TuYa”,“model”:“Radiator valve with thermostat (TS0601_thermostat)”,“name”:“0x84ba20fffe7dafd4”},“enabled_by_default”:false,“entity_category”:“config”,“icon”:“mdi:thermometer”,“name”:“0x84ba20fffe7dafd4 comfort temperature”,“state_topic”:“zigbee2mqtt/0x84ba20fffe7dafd4”,“unique_id”:“0x84ba20fffe7dafd4_comfort_temperature_zigbee2mqtt”,“unit_of_measurement”:“°C”,“value_template”:"{{ value_json.comfort_temperature }}"}’
Info 2023-02-22 21:39:25MQTT publish: topic ‘homeassistant/number/0x84ba20fffe7dafd4/comfort_temperature/config’, payload ‘{“availability”:[{“topic”:“zigbee2mqtt/bridge/state”,“value_template”:"{{ value_json.state }}"}],“command_topic”:“zigbee2mqtt/0x84ba20fffe7dafd4/set/comfort_temperature”,“device”:{“identifiers”:[“zigbee2mqtt_0x84ba20fffe7dafd4”],“manufacturer”:“TuYa”,“model”:“Radiator valve with thermostat (TS0601_thermostat)”,“name”:“0x84ba20fffe7dafd4”},“entity_category”:“config”,“icon”:“mdi:thermometer”,“max”:30,“min”:0,“name”:“0x84ba20fffe7dafd4 comfort temperature”,“state_topic”:“zigbee2mqtt/0x84ba20fffe7dafd4”,“unique_id”:“0x84ba20fffe7dafd4_comfort_temperature_zigbee2mqtt”,“unit_of_measurement”:“°C”,“value_template”:"{{ value_json.comfort_temperature }}"}’
Info 2023-02-22 21:39:25MQTT publish: topic ‘homeassistant/sensor/0x84ba20fffe7dafd4/eco_temperature/config’, payload ‘{“availability”:[{“topic”:“zigbee2mqtt/bridge/state”,“value_template”:"{{ value_json.state }}"}],“device”:{“identifiers”:[“zigbee2mqtt_0x84ba20fffe7dafd4”],“manufacturer”:“TuYa”,“model”:“Radiator valve with thermostat (TS0601_thermostat)”,“name”:“0x84ba20fffe7dafd4”},“enabled_by_default”:false,“entity_category”:“config”,“icon”:“mdi:thermometer”,“name”:“0x84ba20fffe7dafd4 eco temperature”,“state_topic”:“zigbee2mqtt/0x84ba20fffe7dafd4”,“unique_id”:“0x84ba20fffe7dafd4_eco_temperature_zigbee2mqtt”,“unit_of_measurement”:“°C”,“value_template”:"{{ value_json.eco_temperature }}"}’
Info 2023-02-22 21:39:25MQTT publish: topic ‘homeassistant/number/0x84ba20fffe7dafd4/eco_temperature/config’, payload ‘{“availability”:[{“topic”:“zigbee2mqtt/bridge/state”,“value_template”:"{{ value_json.state }}"}],“command_topic”:“zigbee2mqtt/0x84ba20fffe7dafd4/set/eco_temperature”,“device”:{“identifiers”:[“zigbee2mqtt_0x84ba20fffe7dafd4”],“manufacturer”:“TuYa”,“model”:“Radiator valve with thermostat (TS0601_thermostat)”,“name”:“0x84ba20fffe7dafd4”},“entity_category”:“config”,“icon”:“mdi:thermometer”,“max”:35,“min”:0,“name”:“0x84ba20fffe7dafd4 eco temperature”,“state_topic”:“zigbee2mqtt/0x84ba20fffe7dafd4”,“unique_id”:“0x84ba20fffe7dafd4_eco_temperature_zigbee2mqtt”,“unit_of_measurement”:“°C”,“value_template”:"{{ value_json.eco_temperature }}"}’
Info 2023-02-22 21:39:25MQTT publish: topic ‘homeassistant/sensor/0x84ba20fffe7dafd4/force/config’, payload ‘{“availability”:[{“topic”:“zigbee2mqtt/bridge/state”,“value_template”:"{{ value_json.state }}"}],“device”:{“identifiers”:[“zigbee2mqtt_0x84ba20fffe7dafd4”],“manufacturer”:“TuYa”,“model”:“Radiator valve with thermostat (TS0601_thermostat)”,“name”:“0x84ba20fffe7dafd4”},“enabled_by_default”:false,“icon”:“mdi:valve”,“name”:“0x84ba20fffe7dafd4 force”,“state_topic”:“zigbee2mqtt/0x84ba20fffe7dafd4”,“unique_id”:“0x84ba20fffe7dafd4_force_zigbee2mqtt”,“value_template”:"{{ value_json.force }}"}’
Info 2023-02-22 21:39:25MQTT publish: topic ‘homeassistant/select/0x84ba20fffe7dafd4/force/config’, payload ‘{“availability”:[{“topic”:“zigbee2mqtt/bridge/state”,“value_template”:"{{ value_json.state }}"}],“command_topic”:“zigbee2mqtt/0x84ba20fffe7dafd4/set/force”,“device”:{“identifiers”:[“zigbee2mqtt_0x84ba20fffe7dafd4”],“manufacturer”:“TuYa”,“model”:“Radiator valve with thermostat (TS0601_thermostat)”,“name”:“0x84ba20fffe7dafd4”},“enabled_by_default”:false,“icon”:“mdi:valve”,“name”:“0x84ba20fffe7dafd4 force”,“options”:[“normal”,“open”,“close”],“state_topic”:“zigbee2mqtt/0x84ba20fffe7dafd4”,“unique_id”:“0x84ba20fffe7dafd4_force_zigbee2mqtt”,“value_template”:"{{ value_json.force }}"}’
Info 2023-02-22 21:39:25MQTT publish: topic ‘homeassistant/sensor/0x84ba20fffe7dafd4/max_temperature/config’, payload ‘{“availability”:[{“topic”:“zigbee2mqtt/bridge/state”,“value_template”:"{{ value_json.state }}"}],“device”:{“identifiers”:[“zigbee2mqtt_0x84ba20fffe7dafd4”],“manufacturer”:“TuYa”,“model”:“Radiator valve with thermostat (TS0601_thermostat)”,“name”:“0x84ba20fffe7dafd4”},“enabled_by_default”:false,“entity_category”:“config”,“icon”:“mdi:thermometer-high”,“name”:“0x84ba20fffe7dafd4 max temperature”,“state_topic”:“zigbee2mqtt/0x84ba20fffe7dafd4”,“unique_id”:“0x84ba20fffe7dafd4_max_temperature_zigbee2mqtt”,“unit_of_measurement”:“°C”,“value_template”:"{{ value_json.max_temperature }}"}’
Info 2023-02-22 21:39:25MQTT publish: topic ‘homeassistant/number/0x84ba20fffe7dafd4/max_temperature/config’, payload ‘{“availability”:[{“topic”:“zigbee2mqtt/bridge/state”,“value_template”:"{{ value_json.state }}"}],“command_topic”:“zigbee2mqtt/0x84ba20fffe7dafd4/set/max_temperature”,“device”:{“identifiers”:[“zigbee2mqtt_0x84ba20fffe7dafd4”],“manufacturer”:“TuYa”,“model”:“Radiator valve with thermostat (TS0601_thermostat)”,“name”:“0x84ba20fffe7dafd4”},“entity_category”:“config”,“icon”:“mdi:thermometer-high”,“max”:35,“min”:15,“name”:“0x84ba20fffe7dafd4 max temperature”,“state_topic”:“zigbee2mqtt/0x84ba20fffe7dafd4”,“unique_id”:“0x84ba20fffe7dafd4_max_temperature_zigbee2mqtt”,“unit_of_measurement”:“°C”,“value_template”:"{{ value_json.max_temperature }}"}’
Info 2023-02-22 21:39:25MQTT publish: topic ‘homeassistant/sensor/0x84ba20fffe7dafd4/min_temperature/config’, payload ‘{“availability”:[{“topic”:“zigbee2mqtt/bridge/state”,“value_template”:"{{ value_json.state }}"}],“device”:{“identifiers”:[“zigbee2mqtt_0x84ba20fffe7dafd4”],“manufacturer”:“TuYa”,“model”:“Radiator valve with thermostat (TS0601_thermostat)”,“name”:“0x84ba20fffe7dafd4”},“enabled_by_default”:false,“entity_category”:“config”,“icon”:“mdi:thermometer-low”,“name”:“0x84ba20fffe7dafd4 min temperature”,“state_topic”:“zigbee2mqtt/0x84ba20fffe7dafd4”,“unique_id”:“0x84ba20fffe7dafd4_min_temperature_zigbee2mqtt”,“unit_of_measurement”:“°C”,“value_template”:"{{ value_json.min_temperature }}"}’
And this just goes on for a while…
