Tuya switches that have separate RGB button control do not show in HA
I have a couple of these branded by various names, but all look and function exactly the same. They are working fine in Smart Life, but there is no trace of this device, nor the 2x entities it contains that shows up anywhere that I can find in Home Assistant. Cursory look at the logs doesn’t yield any info that I can interpret. I did follow one post that said if a device had 2x switches, you had to rename each in the Smart Life App. I did that, but it didn’t make a difference. Any ideas or does anyone have these working?
Thanks!
Ryan
