Hi, got some Temp/HUM-Sensors from ALI. The round ones without display. According to the seller they should be the type TH03Z. Looking like these:klick. Inside there is a ZTU-Chip.
Using HA wit Z2M:
During pairing they send a model ID :TH02Z.
z2m:mqtt: MQTT publish: topic 'homeassistant/sensor/0xa4c138f8ef7d91e3/linkquality/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"},{"topic":"zigbee2mqtt/0xa4c138f8ef7d91e3/availability","value_template":"{{ value_json.state }}"}],"availability_mode":"all","device":{"hw_version":1,"identifiers":["zigbee2mqtt_0xa4c138f8ef7d91e3"],"manufacturer":"Tuya","model":"Temperature and humidity sensor","model_id":"TH02Z","name":"0xa4c138f8ef7d91e3","via_device":"zigbee2mqtt_bridge_0x1cc089fffedfeee6"},"enabled_by_default":false,"entity_category":"diagnostic","icon":"mdi:signal","name":"Linkquality","object_id":"0xa4c138f8ef7d91e3_linkquality","origin":{"name":"Zigbee2MQTT","sw":"2.2.0","url":"https://www.zigbee2mqtt.io"},"state_class":"measurement","state_topic":"zigbee2mqtt/0xa4c138f8ef7d91e3","unique_id":"0xa4c138f8ef7d91e3_linkquality_zigbee2mqtt","unit_of_measurement":"lqi","value_template":"{{ value_json.linkquality }}"}'
And this is an optical totally different sensor. this one
Would like to see in the devices-screen the right picture. Any chance to get this fixed within Z2M?
