There is may be a thousand topics of this problem, I spent an half of day to fix it without success with the 0.107.7 update…
In the config directory, I created a folder: custom_components and I added a tuya folder into it, I added also an empty init.py file and the climate.py (i found somewhere)…
I edited the climate.py by modifying those properties into that file:
@property def current_temperature(self): """Return the current temperature.""" return self.tuya.current_temperature()/2 @property def target_temperature(self): """Return the temperature we try to reach.""" return self.tuya.target_temperature()/2 @property def target_temperature_step(self): """Return the supported step of target temperature.""" return self.tuya.target_temperature_step()/2
But my damned thermostat still having the temperatures doubled!!
What I missing? Why it do not even try to read the climate.py|? No error…
Regards…
