Tuya thermostat integration problem with Home Assistant
I have a thermostat called Noyo no1 and I’ve connected it to Home Assistant, but the temperature readings change when I open the Tuya app on my phone. Also, there are some issues with the thermostat’s automation settings; for example, I can’t configure hysteresis settings, I can’t tell it to turn on or off when it reaches a certain temperature, and the temperature reading is misleading because it appears later. Please help.
