Tuya TS0041 no entity for automations
Hi community,
I have no switch entity available for automations with my Tuya smart button.
Even though the Logbook shows that the event was fired , for example:
Klicker_01 Press Type event was fired with parameters: {'press_type': 0}
10:47:03 – 2 minutes ago
What should I change?
I’ve already tried some of the suggestions mentioned here:
Switch TS0041 by _TZ3000_adndolvx not working - Third party integrations - Home Assistant Community
…but unfortunately, without success.
“home_assistant”: {
“installation_type”: “Home Assistant OS”,
“version”: “2025.5.0”,
“dev”: false,
“hassio”: true,
“virtualenv”: false,
“python_version”: “3.13.3”,
“docker”: true,
“arch”: “x86_64”,
“timezone”: “Europe/Berlin”,
“os_name”: “Linux”,
“os_version”: “6.12.23-haos”,
“supervisor”: “2025.05.3”,
“host_os”: “Home Assistant OS 15.2”,
“docker_version”: “28.0.4”,
“chassis”: “vm”,
“run_as_root”: true
Sonoff Zigbee 3.0 USB Dongle Plus
Stop buying Tuya devices. They are :face_vomiting:
what do you use ?
does anyone has the same issue ?
https://community.home-assistant.io/t/smartthings-im6001-btp01-button/902627/3?u=tom_l
