Thank you @TonkaNL. I’ve installed the quirk but now cannot [physically] find the sensor anymore
EDIT: found it, hiding in a pocket! So far, with the quirk installed, I haven’t seen any update for the past 10 minutes, though it had a few fast ones, initially, every few seconds.
The reporting interval of my device varies based on the delta of the reported value. If no significant change is measured, no update is given. It can take hours. Try to warm up or cool the device and see what happens.
I have found on the GitHUB here a way to make this sensor report temperature and humidity without using a Tuya hub.
In short you go to Settings → Device & Services → Integrations → ZHA → Devices → Your sensor, then press the 3 dots, select “Manage zigbee device” → Clusters
Under dropdown box “Attributes of the selected cluster”:
Select item no 1 from the list below (‘manufacturer (id: 0x0004)’)
Press briefly the reset button on top of your device
Click “READ ATTRIBUTE”
Make sure some value is populated in the “Value” box above (takes roughly a second or so)
Repeat steps 1. to 5. for all the items in the list below:
‘zcl_version (id 0x0000)’
‘app_version (id 0x0001)’
‘model (id 0x0005)’
‘power_source (id 0x0007)’
‘attr_reporting_status (id 0xfffe)’
After this my device started to report the temperature and humidity values.
(I think this is the same as the one in posts from @TonkaNL and @ha-username above - its branded as Aubess.)
AVOID THIS ONE.
When mine work they report in 0.1°C steps but only at 30 minute intervals. More importantly one of them regularly goes to sleep.
(Maybe they are OK if you use a Tuya hub, and maybe OK with a quirk. But as a beginner I have no experience with quirks.)
However the wifi ones that look the same are pretty good:
And they are very cheap (£7.99 from eBay in the UK).
But they’re a pain to set up especially if you try the Local Tuya integration!
And obviously zigbee is much more preferrable than wifi (as I have recently learnt ).
I have the exact one above but also the round ones. Somehow, they report the temperature randomly, perhaps only on big swings, but I am frequently 4h+ without any temperature data from some of them, both round and rectangle ones.
Round:
Round again:
Rectangle, but usually it also has hour-long gaps:
Nexus 433Mhz sensor, not recommended, just for comparison:
I would recommend to stay away from any ‘cheap’ zigbee sensors if possible, I’d hoped they would be more reliable than 433Mhz + OpenMQTTGateway.
Not sure about WiFi ones, but it would be cheap to add a DHT11 sensor to an ESP8266 module running somewhere (we all have a few of them) and get more reliable data.
EDIT: same as @TonkaNL, the quirks do not seem to get applied but the ZigBee devices seem to work, randomly. Perhaps there’s some setting that would tell the sensor how often it should update, once it’s seen online.
The question is: Which sensor is more reliable Any recommendations?
433MHz “Nexus” sensors are pretty good. But the “code” needs to be changes to yaml file everytime battery is replaced (not a big issue as they seem to last long)
So I have stumbled across a fix for my installation that may help others aswell. My ZigBee radio is on home assistants sky connect and I had a notification stating that my radio channels weren’t on the same channel and they needed to be changed, so I changed both channels to 20 and now all my sensors are reporting much more frequently.
I don’t know why, I honestly and just bumbling my way through my install as I have no real coding experience but have an interest in automation so I accidentally solved my issue and I hope this helps others too.
I bought 3 of those. They are TS0201 _Tz3000_xr3htd96. One is more or less DoA, it will only light up its led when I firmly squeeze the sides. Not the button, the sides. The other two are fine. They update regularly on 5 minute intervals for a couple of days now. Using ZHA.
Sorry, im a noob but what do you mean by “both channels”? Tried to change the Chanel of my ZigBee stick to 20, but it didn’t improve.
Using a different stick though.
Best is to install the custom firmware by following the instructions here. This sensor can be used as ZigBee or BLE and with BLE update frequency can be as low as 15 seconds.
Does this firmware work with any of the TS0201 sensors? We know there are a lot of them. I have the one from @semik’s post with the LCD: TZ3000_qaaysllp TS0201.
