Tuya _TZE284_debczeci mmWave radar custom quirk
A battery-powered Tuya 24G mmWave presence radar (_TZE284_debczeci / TS0601) paired in ZHA but exposed no occupancy entity. The fix was a quirks-v2 TuyaQuirkBuilder custom quirk — but most of the debugging time went into things that had nothing to do with the DP mapping. Sharing the lessons because they generalize to any "unsupported Tuya device in ZHA" situation.
A working quirk for me (A rough one developed via trial and error)
Save to /config/custom_zha_quirks/ (filename ending .py), with zha: custom_quirks_path: /config/custom_zha_quirks/ in configuration.yaml:
python
"""ZHA quirk for _TZE284_debczeci TS0601 - 24G mmWave presence radar."""
from __future__ import annotations
import zigpy.types as t
from zigpy.quirks.v2.homeassistant import EntityType
from zigpy.quirks.v2.homeassistant.binary_sensor import BinarySensorDeviceClass
from zigpy.zcl.clusters.measurement import OccupancySensing
from zigpy.zcl.clusters.general import PowerConfiguration
from zhaquirks.tuya import TuyaLocalCluster
from zhaquirks.tuya.builder import TuyaQuirkBuilder
class TuyaOccupancySensing(OccupancySensing, TuyaLocalCluster):
    """Occupancy cluster backed by Tuya DP1."""
class TuyaPowerConfiguration(PowerConfiguration, TuyaLocalCluster):
    """Power config cluster backed by Tuya DP4."""
class RadarSensitivity(t.enum8):
    """Radar sensitivity (DP9)."""
    Low = 0x00
    Medium = 0x01
    High = 0x02
class FadingTime(t.enum8):
    """Presence clear delay (DP10)."""
    S15 = 0x00
    S30 = 0x01
    S60 = 0x02
def _presence(value):
    # This unit uses trueFalse0: 0 = present, 1 = absent.
    # ZCL occupancy: 1 = occupied, 0 = unoccupied.
    return 1 if int(value) == 0 else 0
def _battery(value):
    # DP4: 0-100 percent -> ZCL battery_percentage_remaining is 0-200 (half-percent).
    return min(200, int(value) * 2)
    TuyaQuirkBuilder("_TZE284_debczeci", "TS0601")
    .applies_to("_TZE204_debczeci", "TS0601")
    .adds(TuyaOccupancySensing)
    .adds(TuyaPowerConfiguration)
    .tuya_dp(
        dp_id=1,
        ep_attribute=TuyaOccupancySensing.ep_attribute,
        attribute_name=OccupancySensing.AttributeDefs.occupancy.name,
        converter=_presence,
    .tuya_dp(
        dp_id=4,
        ep_attribute=TuyaPowerConfiguration.ep_attribute,
        attribute_name=PowerConfiguration.AttributeDefs.battery_percentage_remaining.name,
        converter=_battery,
    .binary_sensor(
        TuyaOccupancySensing.cluster_id,
        device_class=BinarySensorDeviceClass.OCCUPANCY,
        entity_type=EntityType.STANDARD,
        translation_key="occupancy",
        fallback_name="Occupancy",
    .tuya_enum(
        dp_id=9,
        attribute_name="radar_sensitivity",
        enum_class=RadarSensitivity,
        translation_key="radar_sensitivity",
        fallback_name="Radar sensitivity",
    .tuya_enum(
        dp_id=10,
        attribute_name="fading_time",
        enum_class=FadingTime,
        translation_key="fading_time",
        fallback_name="Fading time",
    .add_to_registry()
(DP map for this unit: DP1 presence, DP4 battery. Confirm yours by capturing live frames.)
bonjour,
voici un code qui fonctionne by Socrate :wink:
"""Tuya TS0601 human presence sensor _TZE284_debczeci."""
from enum import Enum
from typing import cast
from zigpy import types as t
def _true_false_0_to_occupancy(value: int) -> int:
    """Convert Tuya 'trueFalse0' to ZCL OccupancySensing.occupancy."""
class PirSensitivity(t.enum8):
    """PIR sensor sensitivity."""
    low = 0
    middle = 1
    high = 2
class PirTime(t.enum8):
    """PIR delay time in seconds."""
    s15 = 0
    s30 = 1
    s60 = 2
class IhsenoPresenceOccupancy(OccupancySensing, TuyaLocalCluster):
    """Occupancy cluster backed by Tuya presence datapoints."""
    # On force la reconnaissance de la signature exacte vue dans ton diagnostic
    .applies_to("_TZE284_debczeci", "TS0601")
    # On ajoute le cluster de présence
    .adds(IhsenoPresenceOccupancy)
    # DP 1: presence (0=mouvement, 1=pas de mouvement)
    .tuya_dp(
        dp_id=1,
        ep_attribute=IhsenoPresenceOccupancy.ep_attribute,
        converter=_true_false_0_to_occupancy,
    # DP 4: batterie (0-100%)
    .tuya_battery(
        dp_id=4,
        scale=2,
    # DP 9: Sensibilité PIR
    .tuya_enum(
        dp_id=9,
        attribute_name="pir_sensitivity",
        enum_class=cast(type[Enum], PirSensitivity),
        translation_key="pir_sensitivity",
        fallback_name="PIR sensitivity",
    # DP 10: Délai PIR
    .tuya_enum(
        dp_id=10,
        attribute_name="pir_time",
        enum_class=cast(type[Enum], PirTime),
        translation_key="pir_time",
        fallback_name="PIR delay",
    # Cette option force l'ajout même si la signature ne correspond pas à 100% à un profil standard
    .add_to_registry(force_add_cluster=True)
