Tuya Universal IR
HI
I have a tuya universal ir. I am trying to setup an automation with it.
I can see the devices that are connected to the ir but none of them have any possible actions to select ?
Basically I want the automation to turn on the tv and the mibox at the same time.
Sugestions
mrrcomp
You probably want the remote.send_command action. If not that then there are three services listed here: Remote - Home Assistant
@tom_l
Thanks for the suggestion. I looked for the remote in the actions but its not there …
Any other idea?
Regards
No unfortunately, I’m not familiar with the device. Someone else may be able to help. Have you tried searching the forum?
I programmed my IR blaster first in Tuya app with the desired device and after that I made “tap to run” scenes in Tuya which can be triggered with HA.
@Sonikky
Thanks for the input. . Once i have the tap to run in tuya how do i sync and trigger it in HA?
Regards
They can be found via Tuya integration. In automations there is scenes: activate action.
tuya
tuya2
