Tuya Vacuum robot
Hello everyone. I have a Chinese vacuum cleaner that I saw in the world that changes the brand but it is the same. It is controlled from the Tuya app. It allows me to use the basic options but there are others that the application uses and that in Home Assistant does not. For example the map, barriers, sectors, mop selection. Do you know if there is any way in which you can get more sensors than the ones it gives me by default?
Another important thing that it does not have is a sensor that indicates that something is stuck
Thank you very much
