Tuya Vibration Sensor modifying sensitivity
Hi there.
Has anyone been able to modify the sensitivity of Tuya Vibration Sensor?
I have paired the sensor through Zigbee.
What should be edited here:
Thanks in advance!
Hi A Ö,
What does the sensor currently display? If it’s a number, you could perhaps make a new sensor using the compensation integration and scale your outpit to meet your needs better.
Where can I see what the sensor is currently displaying? This may be a dumb question, but I am quite new to HA and still learning :slight_smile:
Open your Home Assistant instance and show your state developer tools.
It shows up as a binary sensor, so not a number.
OK,
binary sensor.
No idea then.
It’s edited here:
I also have the same question. All I have is this under Clusters.
I think I managed to turn up the sensitivity by changing the value to 1. It now reacts to my doorbell vibrations.
