Tuya WiFi - Infrared bridge and temp & humidity sensor
I’m stuck at my very first automation… (I’m not dumb and into IT but 73 years old. New things take longer…)
I have been using the Tuya app for a while and found it quite intuitive to create a scene there to switch my dumb AC on to cooling, automatic fan speed and set to 24°C.
That was working fine.
I’ve now got a Raspberry Pi4 set up running HA.
It was easy to incorporate the Tuya integrations and they showed up in the default dashboard and work.
However, I wish to change the temperature at which it is triggered, and add some automation for next winter (for heating).
This is where I get stuck:
I can’t find anywhere to edit the automation and there are no scenes attached to the Tuya device in HA. Nor can I find the entities for the IR bridge in HA.
I can’t find any .yaml files anywhere - in case I can make sense of them - either…
I’m quite lost now.
Can someone please walk me through the issues?
Also: how can I tell if my automations are running locally in my Pi4 or are still being run from the Tuya cloud?
