Tuya WiFi Led Strips
Does anyone know if I can somehow relatively simply use the WiFi controller in this package with HA?
Now,I can’t control it with https://github.com/phatpenguintn/homeassistant-light.merkury
error code
Update for light.light1 fails
File “/config/custom_components/light/merkury.py”, line 227, in update
status = self._device.status()
File “/config/deps/lib/python3.7/site-packages/pytuya/init.py”, line 259, in status
data = self._send_receive(payload)
File “/config/deps/lib/python3.7/site-packages/pytuya/init.py”, line 171, in _send_receive
data = s.recv(1024)
ConnectionResetError: [Errno 104] Connection reset by peer
File “/usr/src/app/homeassistant/helpers/entity.py”, line 220, in async_update_ha_state
await self.async_device_update()
File “/usr/src/app/homeassistant/helpers/entity.py”, line 379, in async_device_update
await self.hass.async_add_executor_job(self.update)
File “/usr/local/lib/python3.7/concurrent/futures/thread.py”, line 57, in run
File “/config/custom_components/light/merkury.py”, line 245, in update
raise ConnectionError(“Failed to update status.”)
ConnectionError: Failed to update status.
the tuya app
Have you looked at tuya convert? Its possible that you could flash it over to tasmota and get it working that way. I’ve flashed 2 of the merkury strips over to tasmota with tuya convert, as well as 3 wifi switches. It works reasonably well.
Unfortunately I have 2 pcs Tuya compatible LED stuff (1 LED bulb, 1 LED strip with Spider T controller).
None of them works correctly in Home Assistant, it sees them but eventually they are unusable.
All of them works in Tuya app perfectly.
