For me, it paired just fine and even was issuing events properly. Then I woke up the next morning to it being totally unresponsive and issuing no zigbee commands.
I’m using Node-Red, the Sonoff Zigbee Pro stick, and ZHA.
I am having a similar problem. I just tried to set this up today. ZHA added a device with battery entity successfully, but I haven’t been able to see any events in zha_event. I’m hoping for an easy fix.
I ordered 2 of them. The second paired and continued to send events. Sadly, not all the events are supported. It only registers the single-click and the rotate left/right. Press & rotate isn’t supported. Nor are double or triple click. I have a feeling that this device needs a quirk and I have no idea how to make them.
it has two modes, you can “triple click” to toggle between them. One recognizes a few commands and one does nothing (as far as zha_event is concerned). So try 3x fast clicks then listen to zha_event
I’m in the same boat as @JDHayes though. Only get events for single click and rotate. Using Nortek stick w/ ZHA.
Try doing a triple-click and see if it will send events then. The knob seems to have two modes. One of the supports a single press and rotate events. When you triple-click, you get into the other mode and HA doesn’t handle it properly.
Tried triple click to attempt and change mode, events just don’t show up. I will put this in a box and attempt to set it up later. You are correct that it has two modes and it does seem to be stuck in a certain mode that is not supported.
I just installed one. I can toggle my light with a single click, change brightness by rotating, and toggle my fan with a double click. I cannot get the long press to work.
