Tuya Zigbee ZTH05 thermometer not updating values after sometime
Hello
I have configured my ZTH05 thermometer succesfully and was registering temperature and humidity values but after sometime, it has stopped sending values. However, in the screen of the device the values are changing.
I have checked the zigbee2mqqt status and the device appears as online and with good quality:
Any Idea where the problem is??
I have the same Problem.
I have 2 of them one seems to work fine. I think i will try reset and try it again.
Update:
I have deleted the sensor and connected it again. Now it seems to work again.
Ok, mine seems to be defective as now there is no connection and the screen is off. I’ve tested replacing the battery but nothing happened… I will return it and try the xiaomi BT thermometers
Now I have 4 of them.
I noticed, that problems starts if the connection is “not strong enough”. If the Sensor is next to my system the problem does not occur, but the problems increase if the devices are “too far” away, which is weird since the connection should still be more than good enough.
I think this devices are indeed not that great…
I have a new ZTH05.
How do I pair it with Z2M?
I enable paring in Z2M and I push the button on the backside of the device but it doesn’t showup in Z2M
Thank you!
