Hi there!
I’m having a lot of fun with Homeassistant media-wise and wanted to share this small project that:
- Takes a voice command: e.g. who currently boadcasts: “Topic”
- Searches throug the epg for the Topic
- zappes throug the tv channels containing the Topic in title or description or …
My setup:
- HA + TVheadend running on central server in different docker-container
- No TVHeadined rec integration installed (HACS)
- Kodi running on a raspi, connected to a projector
Setup this sensor that queries the epg from tvh:
### TVH
- platform: rest
#this only gets the currently running epg entries
resource_template: "http://192.168.178.59:9981/api/epg/events/grid?mode=now"
method: GET
headers:
Content-Type: "application/json"
#the scan interval is set to very high since the sensor is triggered every time the script runs
scan_interval: 360000
Then I have the following script to find the channels + zapp through them
alias: Zappe durch Sender
description: Zappt durch Kanäle, auf denen das Thema aktuell läuft
mode: queued
fields:
suchwort:
description: Suchbegriff
required: true
example: Sport
sequence:
- action: homeassistant.update_entity
metadata: {}
entity_id:
- sensor.tvh_epg
- variables:
#this is mapping from the returned channel names from the script to the content_id for the media.player
mapping:
PHOENIX HD: 1
WDR HD Köln: 3
TOGGO plus: 4
ntv: 6
SAT.1: 7
NDR FS NDS HD: 8
zdf_neo HD: 12
SWR BW HD: 13
VOX: 15
ORF2E: 17
arte HD: 18
RTLup: 19
DMAX HD: 20
N24 Doku: 21
TELE 5: 23
SAT.1 Gold: 24
SPORT1: 25
WELT: 26
Bibel TV HD: 27
Channel21: 28
Comedy Central: 29
sixx: 30
DF1 HD: 32
rbb Berlin HD: 33
Nick: 34
BR Süd HD: 36
MDR Sachsen HD: 37
RTL: 38
DELUXE MUSIC: 39
ProSieben MAXX: 41
KiKA HD: 42
3sat HD: 46
hr-fernsehen HD: 48
SR Fernsehen HD: 52
MTV: 53
ARD alpha HD: 54
DMF: 56
Super RTL: 57
RTLZWEI: 49
ZDF HD: 55
VOXup: 2
NITRO: 10
ProSieben: 47
Das Erste HD: 5
ZDFinfo HD: 9
kabel eins Doku: 14
tagesschau24 HD: 16
ONE HD: 43
DOKUSAT: 44
kabel eins: 45
Eurosport 1: 50
eintraege: "{{ state_attr('sensor.tvh_epg', 'entries') }}"
jetzt: "{{ now().timestamp() | int }}"
sender_ids: >-
{% set sw = suchwort | lower %} {% set ns = namespace(ids=[]) %} {% for
e in eintraege %}
{% set start = e.start %}
{% set stop = e.stop %}
{% if start <= jetzt <= stop %}
{% set title = (e.title | string | lower) %}
{% set subtitle = (e.subtitle | string | lower if 'subtitle' in e else '') %}
{% set description = (e.description | string | lower if 'description' in e else '') %}
{% if sw in title or sw in subtitle or sw in description %}
{% set cid = mapping.get(e.channelName) %}
{% if cid is not none %}
{% set ns.ids = ns.ids + [cid] %}
{% endif %}
{% endif %}
{% endif %}
{% endfor %} {{ ns.ids }}
- repeat:
for_each: "{{ sender_ids }}"
sequence:
- target:
entity_id: media_player.libreelec
media_content_type: channel
media_content_id: "{{ repeat.item }}"
action: media_player.play_media
- delay:
#here you can set the pause between zapps
seconds: 10
And last but not least the automation for triggering the whole thing via voice. Do not forget to enter your script-name:
alias: Voice - Wo läuft gerade (TV)
description: ""
triggers:
- command: Wo läuft gerade {thema}
trigger: conversation
actions:
- metadata: {}
suchwort: "{{ trigger.slots.thema }}"
action: script.<name-of-your-script>
mode: single
Hope it works for you, I use it very often, it puts the ‘fun’ back into linear tv
