Hello All
I have a geofence node red flow that is working fine.
I would like to improve my solution
Current ly i have a zone home set at 150 meters that is used to trigger home and away flows. As i said this works fine.
This is fine for when i leave home.
However i would like to trigger my entering home way before the 150 meters. I would like to trigger arriving home at 300 meters.
I tried to set 2 zones in home assistant one at 150 called home and one at 300 meters called away. This does not seem to work do i need to set identical zones in owntracks?
How can i accomplish this?
Thank you for your help in advance
