Two 16x16 LED Matrix display
I am working on a project to use an LED matrix to display a MQTT received text.
I got it working on a 8x32 matrix using the code available on ESPHome.
I am not trying to finalize the project on my actual hardware which uses 2 x 16x16 matrix displays side by side to create a 16x32.
I cannot figure out the pixel mapping for the life of me. Anyone has done this before or any guidance on how to go about it in ESPHome?
This is the configuration I have attached the displays as:
As I am debugging, I know that both sides work… Just can’t read what’s displayed as it is not mapped correctly.
Any help or guidance?
EDIT:
This is the code I am working with. With it now I can see the text go across the top, seamlessly over both units. But the text is mirrored.
#Name of the project and other subsitutions
substitutions:
  project: Gallery Door LED Controller
  xscrollpadding: "4" # in pix
#Include the board used
<<: !include common/mqtt_credentials.yaml
<<: !include common/esphome/esp32.yaml
#include common Wifi-OTA-API, etc
<<: !include common/common_for_mqtt.yaml
#include logger
<<: !include common/logger.yaml
binary_sensor:
#Include the status
  - !include common/binary_sensors/status.yaml
switch:
  #Include restart button
  - !include common/switches/restart.yaml
#Include wifi signal sensor
  - !include common/sensors/wifi_signal.yaml
  - !include common/sensors/uptime.yaml
text_sensor:
  - platform: mqtt_subscribe
    internal: true
    topic: gallery_door/led_controller/text
    on_value:
      then:
        - if:
            condition:
              lambda: return true;
            then:
              lambda: id(gallery_door_led_controller_text).publish_state(x);
    internal: true
font:
  - file: "fonts/arial.ttf"
  - file: "fonts/materialdesignicons-webfont.ttf"
    glyphs: [
      # Wifi
      '󰤯', # mdi-wifi-strength-outline
      '󰤟', # mdi-wifi-strength-1
      '󰤢', # mdi-wifi-strength-2
      '󰤥', # mdi-wifi-strength-3
      '󰤨', # mdi-wifi-strength-4
color:
  - id: my_red
    red: 100%
    green: 0%
    blue: 0%
  - id: my_green
    red: 0%
    green: 100%
    blue: 0%
  - id: my_blue
    red: 0%
    green: 0%
    blue: 100%
  - id: my_yellow
    red: 100%
    green: 100%
    blue: 0%
  - id: my_black
    red: 0%
    green: 0%
    blue: 0%
# Configure WS2812
light:
  - platform: fastled_clockless
    chipset: WS2812b
    pin: GPIO5
    num_leds: 512
    rgb_order: GRB
    name: $project LED Matrix
    default_transition_length: 0s
    color_correct: [50%, 50%, 50%]
    restore_mode: ALWAYS_ON
    effects:
      - addressable_rainbow:
      - addressable_color_wipe:
      - flicker:
      - strobe:
      - random:
      - addressable_scan:
      - addressable_twinkle:
      - addressable_random_twinkle:
      - addressable_fireworks:
      - addressable_flicker:
          name: Rainbow Effect With Custom Values
          speed: 10
          width: 50
display:
  - platform: addressable_light
    addressable_light_id: gallery_door_led_controller_led_matrix
    width: 32
    height: 16
    pixel_mapper: |-
      int iMatrixOffset = y >= 16 ? 512 : 0;
      if (x % 2 == 0) {
        return (x * 16) + (y % 16) + iMatrixOffset;
      return (x * 16) + iMatrixOffset + (14 - (y % 16));
    rotation: 180°
    update_interval: 200ms
    pages:
      - id: page1
        lambda: |-
              if (id(mqtt_client)->is_connected()) {
                // do something if MQTT is connected
                static uint16_t xpos = 0;
                int x_start, y_start;
                int width, height;
                it.get_text_bounds(0, 16, "MQTT Connected", id(text_font_tiny),
                    TextAlign::TOP_LEFT, &x_start, &y_start, &width, &height);
                it.print(-(xpos % (width + $xscrollpadding)), -2,
                  id(text_font_tiny), Color(id(my_blue)),
                  TextAlign::TOP_LEFT, "MQTT Connected");
                xpos++;
      - id: page2
        lambda: |-
              it.print(0, 0, id(icon_font_10), Color(id(my_blue)), TextAlign::TOP_LEFT, "󰽔");
      - id: page3
        lambda: |-
              // Draw the same rectangle, but this time filled.
              //it.filled_rectangle(0, 0, it.get_width(), it.get_height());
              it.fill(my_red);
      - id: page4
        lambda: |-
              it.fill(my_black);
      - id: page5
        lambda: |-
              const char * text = id(gallery_door_led_controller_text_topic).state.c_str();
              int width, height;
              it.get_text_bounds(0, 0, text, id(text_font_tiny),
                id(text_font_tiny), Color(id(my_green)),
                TextAlign::TOP_LEFT, text);
              xpos++;
interval:
  - interval: 2s
    then:
      if:
        condition:
          lambda: |-
            return id(gallery_door_led_controller_text).state == "STOP";
        then:
          - display.page.show: !lambda |-
              static int pagenum = 0;
              static display::DisplayPage* pages[] = {id(page2), id(page3)};
              auto page = pages[pagenum++];
              if (pagenum >= 2)
                pagenum = 0;
              return page;
          - component.update: gallery_door_led_controller_display_matrix
  - interval: 2s
    then:
      if:
        condition:
          lambda: |-
            return id(gallery_door_led_controller_text).state == "START";
        then:
              static display::DisplayPage* pages[] = {id(page5), id(page3)};
              if (pagenum >= 2)
                pagenum = 0;
              return page;
