Two automation in one need little help
Two automation for on and off. When PIR from node1 detect motion and microwave already detecting movement turn on RED LED and buzzer (and must stop one buzzing bip patern from before) on node1 and on node2 turn on GREEN LED and buzzer. This two scrip work good.
Automation On
- id: 'AutoOn'
  alias: Alarm On
  description: ''
  - type: motion
    platform: device
    device_id: node1
    entity_id: binary_sensor.sensornode_pir
    domain: binary_sensor
    for:
      hours: 0
      minutes: 0
      seconds: 1
  condition:
  - type: is_motion
    condition: device
    device_id: node1
    entity_id: binary_sensor.sensornode_microwave
  - type: turn_on
    device_id: node2
    entity_id: switch.micro_buzz
    domain: switch
  - type: turn_on
    device_id: node2
    entity_id: switch.green_led
    domain: switch
  - type: turn_off
    device_id: node1
    entity_id: switch.bip_patern
    domain: switch
  - type: turn_on
    device_id: node1
    entity_id: switch.biping
    domain: switch
- type: turn_on
    device_id: node1
    entity_id: switch.red_led
    domain: switch
  mode: single
Automation Off
- id: 'AutoOff'
  alias: Alarm Off
  description: ''
  - type: no_motion
    platform: device
    device_id: nod1
  - type: no_motion
    platform: device
    device_id: nod1
  condition: []
  - type: turn_off
    device_id: node2
    domain: switch
  - type: turn_off
    device_id: node2
    domain: switch
  - type: turn_off
    device_id: node1
    domain: switch
- type: turn_off
    device_id: node1
    domain: switch
  mode: single
Then I try On and Off in one automation
- id: 'autonation OnOff'
  alias: Alarm OnOff
  - platform: state
    to: 'on'
    for: '00:00:01'
  - platform: state
    to: 'off'
    for: '00:00:05'
  condition:
  - type: is_motion
    condition: device
    device_id: node1
  - service: "switch.turn_{{ trigger.to_state.state }}"
  - type: turn_off
    device_id: node1
    domain: switch
  mode: single
Buzzer on node1 is much shorter then on node2 and led on nodi 1 and 2 sometime dont go off.
Can you help? plz…
Use the debugging trace in Configuration / Automations to see why it does not do what you expect.
Probably the condition. PIR no movement and Microwave no movement won’t do any actions.
Yes I see but how to add two conditions. When PIR and Microwave dont have movment for let say 5 sec to put all Led and Buzzer off…
I try this with CONDITIONS but now LED and buzzer dont start at all where Im wrong?
  alias: Alarm OnOff
  - platform: state
    to: 'on'
    for: '00:00:01'
  - platform: state
    to: 'off'
    for: '00:00:05'
condition:
    condition: and
    conditions:
        - condition: state
          state: 'on'
        - condition: or
          conditions:
            - condition: state
              state: 'off'
            - condition: state
              state: 'off'
  - type: turn_off
    device_id: node1
    domain: switch
  mode: single
Indentation of condition.
Also your conditions are odd: microwave must be on AND (microwave must be off OR PIR must be off) is the same as microwave must be on AND PIR must be off. Reduces to:
  condition:
    - condition: state
      state: 'on'
    - condition: state
      state: 'off'
