Two esp on a different networks via uart
Hello everyone
I have an esp32 c3 supermini with a wall switch setup via binary sensor and it is work fine to control a garden water pump (the gard water pump has a seperate esp and relay)
im using mqtt to send the wall switch command from esp32 c3 to the esp on the water pump and everyhing is fine
now I want to use a custom homekit firmware on esp8266 to connect it via uart with the esp32 c3 since those two are on different networks
Im using this library for the esp8266
this is the code for esp32 c3
esphome:
  friendly_name: MAM
esp32:
  board: esp32-c3-devkitm-1
  framework:
    type: arduino
# Enable Home Assistant API
api:
  encryption:
    key: "="
ota:
  - platform: esphome
    password: ""
wifi:
  ssid: ""
  password: ""
  manual_ip:
    static_ip: 192.168.100.93
    gateway: 192.168.100.1
    subnet: 255.255.255.0
  ap:
    ssid: "Mam Fallback Hotspot"
    password: ""
captive_portal:
web_server:
  port: 80
uart:
  tx_pin: GPIO21  # TX to ESP8266 RX
  rx_pin: GPIO20  # RX to ESP8266 TX
  baud_rate: 9600
logger:
  level: DEBUG
# Diagnostics: WiFi signal strength
  - platform: wifi_signal
    name: "WiFi Signal Strength (dB)"
    update_interval: 60s
    entity_category: "diagnostic"
  - platform: copy
    source_id: wifi_signal_db
    name: "WiFi Signal Strength (%)"
    unit_of_measurement: "%"
    filters:
      - lambda: return min(max(2 * (x + 100.0), 0.0), 100.0);
  - platform: dht
    pin: GPIO3
    temperature:
      name: "Mam Kitchen Temprature"
      filters:
        - calibrate_linear:
            - 30 -> 21
            - 100 -> 66
    humidity:
      name: "Mam Kitchen Humidity"
    update_interval: 2s
switch:
  - platform: restart
    name: "MAM Restart esp32c3 supermini"
  - platform: gpio
    pin: GPIO8
    inverted: true
globals:
  - id: pump_state
    type: bool
    restore_value: yes
    initial_value: 'false'
# For use with 3.3V input from ESP32-S2's 3.3V pin
binary_sensor:
  - platform: gpio
    pin:
      number: GPIO5
      mode: INPUT_PULLUP
      inverted: true
    name: "Garden Pump Wall Switch"
    filters:
      - delayed_on: 500ms  # Increased from 50ms
      - delayed_off: 500ms  # Increased from 50ms
    on_state:
      - if:
          condition:
            binary_sensor.is_on: wall_switch
          then:
            - mqtt.publish:
                topic: 'gar/switch/garden_pump/command'
                payload: 'ON'
                retain: false
            - uart.write:
                data: "PUMP_ON\n"
      - if:
          condition:
            binary_sensor.is_off: wall_switch
          then:
            - mqtt.publish:
                payload: 'OFF'
                retain: false
            - uart.write:
                data: "PUMP_OFF\n"
  - platform: gpio
    pin:
      number: GPIO6
      mode: INPUT_PULLUP
      inverted: true
    name: "Tank Pump Wall Switch"
    filters:
    on_state:
      - if:
          condition:
            binary_sensor.is_on: wall_switch2
          then:
            - mqtt.publish:
                payload: 'ON'
                retain: false
      - if:
          condition:
            binary_sensor.is_off: wall_switch2
          then:
            - mqtt.publish:
                payload: 'OFF'
                retain: false
mqtt:
  broker: ""
  username: ""
  password: ""
  discovery: true
  discovery_prefix: homeassistant
this is the code for the main file of the homekit setup
#include <Arduino.h>
#include <arduino_homekit_server.h>
#include "wifi_info.h"
#include "my_accessory.h"  // Include the header file
#define LOG_D(fmt, ...)   printf_P(PSTR(fmt "\n") , ##__VA_ARGS__);
void setup() {
	Serial.begin(115200);
	wifi_connect(); // in wifi_info.h
	//homekit_storage_reset(); // to remove the previous HomeKit pairing storage when you first run this new HomeKit example
	my_homekit_setup();
void loop() {
	my_homekit_loop();
	delay(10);
// HomeKit setup and loop
extern "C" homekit_server_config_t config;
void my_homekit_setup() {
	arduino_homekit_setup(&config);
static uint32_t next_heap_millis = 0;
static uint32_t next_report_millis = 0;
void my_homekit_loop() {
	arduino_homekit_loop();
	const uint32_t t = millis();
	if (t > next_report_millis) {
		// report sensor values every 10 seconds
		next_report_millis = t + 10 * 1000;
		my_homekit_report();
	if (t > next_heap_millis) {
		// Show heap info every 5 seconds
		next_heap_millis = t + 5 * 1000;
		LOG_D("Free heap: %d, HomeKit clients: %d",
				ESP.getFreeHeap(), arduino_homekit_connected_clients_count());
void my_homekit_report() {
    // FIXME, read your real sensors here.
    float t = random_value(10, 30);
    float h = random_value(30, 70);
    float l = random_value(1, 10000);
    uint8_t c = random_value(0, 10) < 5 ? 1 : 0;  // 1 = detected, 0 = not detected
    bool m = random_value(0, 10) < 5;  // Motion detected is a boolean value
    uint8_t o = random_value(0, 10) < 5 ? 1 : 0;  // 1 = occupancy detected, 0 = not detected
    cha_temperature.value.float_value = t;
    homekit_characteristic_notify(&cha_temperature, cha_temperature.value);
    cha_humidity.value.float_value = h;
    homekit_characteristic_notify(&cha_humidity, cha_humidity.value);
    cha_light.value.float_value = l;
    homekit_characteristic_notify(&cha_light, cha_light.value);
    cha_contact.value.uint8_value = c;
    homekit_characteristic_notify(&cha_contact, cha_contact.value);
    cha_motion.value.bool_value = m;
    homekit_characteristic_notify(&cha_motion, cha_motion.value);
    cha_occupancy.value.uint8_value = o;
    homekit_characteristic_notify(&cha_occupancy, cha_occupancy.value);
    LOG_D("t %.1f, h %.1f, l %.1f, c %u, m %u, o %u", t, h, l, c, (uint8_t)m, o);
int random_value(int min, int max) {
	return min + random(max - min);
and this is the code for the accessory file of the homekit setup
#include <homekit/homekit.h>
#include <homekit/characteristics.h>
#include <Arduino.h>  // Make sure we can use Serial communication
void my_accessory_identify(homekit_value_t _value) {
    printf("accessory identify\n");
// Define the characteristics (no need for extern "C" here)
homekit_characteristic_t cha_temperature = HOMEKIT_CHARACTERISTIC_(CURRENT_TEMPERATURE, 1);
homekit_characteristic_t cha_humidity = HOMEKIT_CHARACTERISTIC_(CURRENT_RELATIVE_HUMIDITY, 1);
homekit_characteristic_t cha_light = HOMEKIT_CHARACTERISTIC_(CURRENT_AMBIENT_LIGHT_LEVEL, 1);
homekit_characteristic_t cha_contact = HOMEKIT_CHARACTERISTIC_(CONTACT_SENSOR_STATE, 0);
homekit_characteristic_t cha_motion = HOMEKIT_CHARACTERISTIC_(MOTION_DETECTED, false);
homekit_characteristic_t cha_occupancy = HOMEKIT_CHARACTERISTIC_(OCCUPANCY_DETECTED, 0);
// New Pump Switch characteristic
homekit_characteristic_t cha_pump_switch_on = HOMEKIT_CHARACTERISTIC_(ON, false);
homekit_accessory_t *accessories[] = {
    HOMEKIT_ACCESSORY(.id=1, .category=homekit_accessory_category_bridge, .services=(homekit_service_t*[]) {
        HOMEKIT_SERVICE(ACCESSORY_INFORMATION, .characteristics=(homekit_characteristic_t*[]) {
            HOMEKIT_CHARACTERISTIC(NAME, "Multiple Sensors"),
            HOMEKIT_CHARACTERISTIC(MANUFACTURER, "Arduino HomeKit"),
            HOMEKIT_CHARACTERISTIC(SERIAL_NUMBER, "0123456"),
            HOMEKIT_CHARACTERISTIC(MODEL, "ESP8266/ESP32"),
            HOMEKIT_CHARACTERISTIC(FIRMWARE_REVISION, "1.0"),
            HOMEKIT_CHARACTERISTIC(IDENTIFY, my_accessory_identify),
            NULL
        NULL
    HOMEKIT_ACCESSORY(.id=8, .category=homekit_accessory_category_switch, .services=(homekit_service_t*[]) {
            HOMEKIT_CHARACTERISTIC(NAME, "Garden Pump Switch"),
            NULL
        HOMEKIT_SERVICE(SWITCH, .primary=true, .characteristics=(homekit_characteristic_t*[]) {
            &cha_pump_switch_on,
            NULL
        NULL
    NULL
homekit_server_config_t config = {
    .accessories = accessories,
    .password = "111-11-111"
Im really noob when it comes to aurduino and I wonder if this setup is possible or not I couldnt manage to have any result just had the switch appear from the homekit but id did nothing
the connection is rx to tx and vise versa for the uart
I would appreciate any input
