Two Grow Fingerprint sensors
Hi guys,
I’m new in YAML. I want to use two Grow Fingerprint sensors on my ESP32.
Please, how can I declare two? If I try to do it like a list, it shows Error by the “on_finger_scan…”.
Thank you for every help/comment.
The id has to be unique for each instance. You can’t reuse id names.
You mean the row 21 - id: fingerprint_in and row 25 - id: fingerprint_out?
These are not same.
I see, you have the 2 id’s on the same sensing pin. Did you try different sensing pins for each reader?
Yes, I tried with GPIO32 now. But the error not about the sensing pin.
I’m new by YAML and I don’t know how to make two instance of the component.
Can I just make it as list with character ’ - ’ before the id?
It depends on how the integration was written. It may very well only support a single reader. You could file a feature request/bug report on github.
Ok, I made a request to update. fingerprint_grow multiple instances · Issue #1522 · esphome/feature-requests · GitHub
If somebody knows how to make two instances of the “fingerprint_grow” conponent, please let me know :wink:
I tried to create two instances of the object without the events and it looks is working.
Just if I add the events, it says: fault. Looks like a bug in the component, or my fault by using YAML?
esphome:
  platform: ESP32
  board: esp32dev
uart:
  - id: uart_in
    tx_pin: GPIO17
    rx_pin: GPIO16
    baud_rate: 57600
  - id: uart_out
    tx_pin: GPIO23
    rx_pin: GPIO22
    baud_rate: 57600
fingerprint_grow:
    uart_id: uart_in
    sensing_pin: GPIO32
    uart_id: uart_out
    sensing_pin: GPIO12
Thank for help and some Idea
Oh I see what I think is the problem, all your automations were under the same entry. All actions for uart_in are under uart_out. Separate them to their respective entries.
Hi Mike,
I’m not understanding, what you mean with “Separate them to their respective entries.”
Can you write some example?
Thank you very much.
fingerprint_grow:
### this is the entry
  sensing_pin: GPIO12 ##use different pins for each sensor
  uart_id: uart_finger_in
###end of entry
###start of automations
  on_finger_scan_matched:
    - text_sensor.template.publish:
        state: "Authorized finger"
    - switch.turn_on: gate
    - delay: 500ms
    - switch.turn_off: gate
  on_finger_scan_unmatched:
        state: "Unauthorized finger"
### end of automations
### start second entry
  sensing_pin: ##use different pins for each sensor
  uart_id: uart_finger_out
###end of entry
###start of automations for second entry
    - delay: 500ms
Ok, it’s not working on first, but after small correction looks good. (valid by ESPHome)
fingerprint_grow:
    uart_id: uart_in
    sensing_pin: GPIO32
      - switch.turn_on: relay_unlock
      - fingerprint_grow.aura_led_control:
          state: BREATHING
          speed: 200
          color: BLUE
          count: 1
      - delay: 500ms
      - switch.turn_off: relay_unlock
    uart_id: uart_out
    sensing_pin: GPIO12
          state: BREATHING
          speed: 200
          color: BLUE
          count: 1
      - delay: 500ms
I thank you. You are great man.
Hello everyone
Thanks for the mentioned code. It helped me but I’ve got a little bit a different and longer yaml-code. When I tried to install this configuration. I’ve got the following warning:
 Too many candidates found for 'fingerprint_grow_id' type 'fingerprint_grow::FingerprintGrowComponent' Some are 'fingerprint_garage', 'fingerprint_tuer'.
In the editor, I can see that this error occurs by the binary sensor, sensor and the services in the api. Could anyone with yaml-experience help me out to separate them as well?
esphome:
  friendly_name: Fingersensor
esp32:
  board: esp32-c3-devkitm-1
  framework:
    type: esp-idf
# Enable logging
logger:
ota:
  - platform: esphome
    password: "secret"
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Fingersensor Fallback Hotspot"
    password: "secret"
captive_portal:
uart:
  - id: uart_garage
    rx_pin: GPIO02
    tx_pin: GPIO03
    baud_rate: 57600
  - id: uart_tuer
    rx_pin: GPIO04
    tx_pin: GPIO05
    baud_rate: 57600
fingerprint_grow:
  - id: fingerprint_garage
    uart_id: uart_garage
    sensing_pin: GPIO01
    sensor_power_pin:
        number: GPIO00
        inverted: true
    idle_period_to_sleep: 5s
      - homeassistant.event:
          event: esphome.test_node_finger_scan_matched
            finger_id: !lambda 'return finger_id;'
            confidence: !lambda 'return confidence;'
          state: BREATHING
          speed: 200
          color: GREEN
          count: 1
          state: "Autorisiert"
          event: esphome.test_node_finger_scan_unmatched
          state: FLASHING
          speed: 25
          color: RED
          count: 2
          state: "Unautorisiert"
    on_enrollment_scan:
          event: esphome.test_node_enrollment_scan
            scan_num: !lambda 'return scan_num;'
          state: FLASHING
          speed: 25
          color: BLUE
          count: 2
          state: ALWAYS_ON
          speed: 0
          color: PURPLE
          count: 0
          state: "Anlernen"
    on_enrollment_done:
          event: esphome.test_node_enrollment_done
          state: BREATHING
          speed: 100
          color: BLUE
          count: 2
          state: "Registrieren"
    on_enrollment_failed:
          event: esphome.test_node_enrollment_failed
          state: FLASHING
          speed: 25
          color: RED
          count: 4
          state: "Fehler"
# Zweiter Sensor
  - id: fingerprint_tuer
    uart_id: uart_tuer
    sensing_pin: GPIO06
    sensor_power_pin:
        number: GPIO00
        inverted: true
          state: BREATHING
          speed: 200
          color: GREEN
          count: 1
          state: FLASHING
          speed: 25
          color: RED
          count: 2
    on_enrollment_scan:
          state: FLASHING
          speed: 25
          color: BLUE
          count: 2
          state: ALWAYS_ON
          speed: 0
          color: PURPLE
          count: 0
          state: "Anlernen"
    on_enrollment_done:
          state: BREATHING
          speed: 100
          color: BLUE
          count: 2
          state: FLASHING
          speed: 25
          color: RED
          count: 4
          state: "Fehler"
# Optional template text sensor for visual feedback
text_sensor:
    name: "Fingerprint State Garage"
    lambda: |-
      return {"-"};
    update_interval: 6s
    name: "Fingerprint State Tür"
    lambda: |-
      return {"-"};
    update_interval: 6s
# Optional sensors
binary_sensor:
  - platform: fingerprint_grow
    name: "Fingerprint Enrolling"
    fingerprint_count:
    last_finger_id:
      name: "Letzte Abdruck ID"
    last_confidence:
      name: "Letzte Autorisation"
    status:
    capacity:
    security_level:
      name: "Abdruck Sicherheitslevel"
api:
  encryption:
    key: "secret
  services:
  - service: enroll
    variables:
      finger_id: int
      num_scans: int
    then:
      - fingerprint_grow.enroll:
          num_scans: !lambda 'return num_scans;'
          state: ALWAYS_ON
          speed: 0
          color: PURPLE
          count: 0
  - service: cancel_enroll
    then:
      - fingerprint_grow.cancel_enroll:
  - service: delete
    variables:
      finger_id: int
    then:
      - fingerprint_grow.delete:
  - service: delete_all
    then:
      - fingerprint_grow.delete_all:
Short update.
I couldn’t figure out a solution with one ESP-Board. My shortcut was to buy a second one and have now to each sensor a separate board.
I just created a short video (in German) of how I did it.
Youtube Video
