As you can see below i have 2 icons for one person. I think one is the iphone and the other could be life360? How can i combine these into 1 icon?
It’s a map, right?
Well they show different GPS coordinates so it would be strange if they show up on the same location on a map.
What if the one you say is correct had no GPS reception?
They are both the same device. It’s tracking my iPhone.
Yes it’s a map
One is the Life360 tracker (image)
Other is device_tracker.xxxxxxx_iphone
If I can either merge the 2 or remove the 2nd one I’ll be happy.
Use the Person integration to combine the trackers.
However, see the note at the bottom of this page:
So basically you can’t hide them from the sidebar map but you can choose what to show on the Lovelace map card (e.g. your Person).
You would think that one device GPS would show the same location even if it’s two apps but that is not the case.
I believe it’s due to how you filter out inaccuracies or not at all.
But edit the card and delete one entity.
The map doesn’t show 2 icons when I am at home though. Only while I’m at work. I don’t know if that helps.
I’ll have a read through the person and map pages.
The map card only has the one entity - life360 tracker.
The map does not show icons for trackers in the home zone, which is in the other note in the map document I linked above.
Thanks. I’ll keep looking into it. I did find a duplicate device tracker for my iPhone (got a new phone) so I’ll have to test tomorrow at work if that helps. If not I’ll figure out the person stuff.
Just thought i would post an update. I am at work and i did have 2 icons for myself until i deleted the Home Assistant App from my iPhone and remove the integration. I have now switched to Hassapp for my devices and HA still tracks me but i no longer see 2 icons for myself.
Ok so im back using the home assistant app on my phone and i got 2 icons again.
Using this as an example
I added this to my configuration.yaml
But i still have 2 icons when not at home
What is the configuration of the map card?
