Two parallell wait until nodes?
Has anyone got an idea or successfully set up two wait until nodes so that if either it triggered the sequence will continue.
I have my flow that maintains the Chromecast paused and I thought about adding phone states to the mix.
So, if a phone rings when that person is home and chromecast is playing, pause chromecast.
Now the issue is that here:
I want this wait until to “let go” if the phone state that was ringing or was in a phone call is no longer in use.
If I split the sequence in two I could but then they will get out of sync since the phone state is not (obviously) linked to my chromecast.
So what can I do to make sure it resumes when the phone call ends and/or when I press play.
[{"id":"94bc1df0.962d9","type":"tab","label":"Chromecast","disabled":false,"info":""},{"id":"21318654.e2391a","type":"trigger-state","z":"94bc1df0.962d9","name":"","server":"4bbca37b.1700ec","exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityid":"media_player.chromecast_vardagsrum","entityidfiltertype":"exact","debugenabled":false,"constraints":[],"constraintsmustmatch":"all","outputs":2,"customoutputs":[],"outputinitially":false,"state_type":"str","x":488,"y":146,"wires":[["f477737f.5411"],["f477737f.5411"]]},{"id":"f477737f.5411","type":"api-current-state","z":"94bc1df0.962d9","name":"Paused?","server":"4bbca37b.1700ec","version":1,"outputs":2,"halt_if":"paused","halt_if_type":"str","halt_if_compare":"is","override_topic":false,"entity_id":"media_player.chromecast_vardagsrum","state_type":"str","state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","blockInputOverrides":false,"x":788,"y":146,"wires":[["449e78d4.0a53d8"],[]]},{"id":"70c4c614.633208","type":"function","z":"94bc1df0.962d9","name":"Payload = rewind 20 seconds","func":"msg.pos = Math.max(parseFloat(msg.data.attributes.media_position-20), 0);\n\nmsg.payload = {\n    data:{\n        \"entity_id\": \"media_player.chromecast_vardagsrum\",\n        \"seek_position\": msg.pos,\n    }\n}\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":1240,"y":140,"wires":[["b07c26bf.0bd798"]]},{"id":"b07c26bf.0bd798","type":"ha-wait-until","z":"94bc1df0.962d9","name":"","server":"4bbca37b.1700ec","outputs":2,"entityId":"media_player.chromecast_vardagsrum","entityIdFilterType":"exact","property":"state","comparator":"is_not","value":"paused","valueType":"str","timeout":"4","timeoutType":"num","timeoutUnits":"minutes","entityLocation":"","entityLocationType":"none","checkCurrentState":true,"blockInputOverrides":true,"x":1480,"y":140,"wires":[["d34eb474.5f9d88"],["a824d3f4.b8e8b"]]},{"id":"a824d3f4.b8e8b","type":"api-call-service","z":"94bc1df0.962d9","name":"rew","server":"4bbca37b.1700ec","version":1,"debugenabled":false,"service_domain":"media_player","service":"media_seek","entityId":"media_player.chromecast_vardagsrum","data":"","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":1630,"y":140,"wires":[["8407d36e.95e2"]]},{"id":"73d459f6.5e5a38","type":"api-call-service","z":"94bc1df0.962d9","name":"play","server":"4bbca37b.1700ec","version":1,"debugenabled":false,"service_domain":"media_player","service":"media_play","entityId":"","data":"{\"entity_id\":\"media_player.chromecast_vardagsrum\"}","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":1340,"y":260,"wires":[["feba9f5a.f1009"]]},{"id":"9dee33b1.46c11","type":"api-call-service","z":"94bc1df0.962d9","name":"pause","server":"4bbca37b.1700ec","version":1,"debugenabled":false,"service_domain":"media_player","service":"media_pause","entityId":"media_player.chromecast_vardagsrum","data":"{\"entity_id\": \"media_player.chromecast_vardagsrum\"}","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":1640,"y":260,"wires":[["a5c1a018.5beed"]]},{"id":"449e78d4.0a53d8","type":"trigger","z":"94bc1df0.962d9","name":"","op1":"","op2":"0","op1type":"pay","op2type":"str","duration":"0","extend":false,"units":"ms","reset":"reset","bytopic":"all","topic":"topic","outputs":1,"x":1000,"y":140,"wires":[["70c4c614.633208","31203888.e182f8"]]},{"id":"c13ebb34.3eba98","type":"function","z":"94bc1df0.962d9","name":"Payload = reset","func":"msg.payload = \"reset\"\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":780,"y":240,"wires":[["449e78d4.0a53d8","219f7aa4.e97486"]]},{"id":"fda46a2d.fa0c38","type":"function","z":"94bc1df0.962d9","name":"Payload = rewind 2 second","func":"msg.pos = parseFloat(msg.data.attributes.media_position-2);\nmsg.payload = {\n    data:{\n        \"entity_id\": \"media_player.chromecast_vardagsrum\",\n        \"seek_position\": msg.pos,\n    }\n}\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":2220,"y":240,"wires":[["b07c26bf.0bd798"]]},{"id":"659bbfe5.21d11","type":"api-current-state","z":"94bc1df0.962d9","name":"Paused?","server":"4bbca37b.1700ec","version":1,"outputs":2,"halt_if":"paused","halt_if_type":"str","halt_if_compare":"is","override_topic":false,"entity_id":"media_player.chromecast_vardagsrum","state_type":"str","state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","blockInputOverrides":false,"x":1945,"y":260,"wires":[["fda46a2d.fa0c38"],["f5e89eb8.9b068"]]},{"id":"53a2715e.bdefb","type":"inject","z":"94bc1df0.962d9","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":580,"y":280,"wires":[["c13ebb34.3eba98"]]},{"id":"8407d36e.95e2","type":"delay","z":"94bc1df0.962d9","name":"","pauseType":"delay","timeout":"2","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":1780,"y":140,"wires":[["b064a90f.beac48"]]},{"id":"feba9f5a.f1009","type":"delay","z":"94bc1df0.962d9","name":"","pauseType":"delay","timeout":"2","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":1490,"y":260,"wires":[["9dee33b1.46c11"]]},{"id":"a5c1a018.5beed","type":"delay","z":"94bc1df0.962d9","name":"","pauseType":"delay","timeout":"2","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":1793,"y":260,"wires":[["659bbfe5.21d11"]]},{"id":"b064a90f.beac48","type":"function","z":"94bc1df0.962d9","name":"msg.payload = {};","func":"msg.payload = {};\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":1950,"y":140,"wires":[["73d459f6.5e5a38"]]},{"id":"f5e89eb8.9b068","type":"link out","z":"94bc1df0.962d9","name":"Release trigger node","links":["2b2f450d.8a73ba"],"x":2075,"y":300,"wires":[]},{"id":"2b2f450d.8a73ba","type":"link in","z":"94bc1df0.962d9","name":"","links":["f5e89eb8.9b068","d34eb474.5f9d88"],"x":615,"y":220,"wires":[["c13ebb34.3eba98"]]},{"id":"d34eb474.5f9d88","type":"link out","z":"94bc1df0.962d9","name":"Release trigger node","links":["2b2f450d.8a73ba"],"x":1615,"y":81,"wires":[]},{"id":"219f7aa4.e97486","type":"api-call-service","z":"94bc1df0.962d9","name":"Volume 1","server":"4bbca37b.1700ec","version":1,"debugenabled":false,"service_domain":"media_player","service":"volume_set","entityId":"media_player.chromecast_vardagsrum","data":"{\"volume_level\":1}","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":980,"y":240,"wires":[[]]},{"id":"31203888.e182f8","type":"api-call-service","z":"94bc1df0.962d9","name":"Volume 0.5","server":"4bbca37b.1700ec","version":1,"debugenabled":false,"service_domain":"media_player","service":"volume_set","entityId":"media_player.chromecast_vardagsrum","data":"{\"volume_level\":0.5}","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":1230,"y":60,"wires":[[]]},{"id":"47975f5e.017b2","type":"inject","z":"94bc1df0.962d9","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":1040,"y":40,"wires":[["31203888.e182f8"]]},{"id":"9b0e9110.ec516","type":"debug","z":"94bc1df0.962d9","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":830,"y":40,"wires":[]},{"id":"2c5bb084.41dfb","type":"trigger-state","z":"94bc1df0.962d9","name":"Andreas","server":"4bbca37b.1700ec","exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityid":"sensor.andreas_phone_state","entityidfiltertype":"exact","debugenabled":false,"constraints":[],"constraintsmustmatch":"all","outputs":2,"customoutputs":[],"outputinitially":false,"state_type":"str","x":60,"y":100,"wires":[["e6e436df.70c088"],[]]},{"id":"43b5802.a9ea28","type":"api-call-service","z":"94bc1df0.962d9","name":"pause","server":"4bbca37b.1700ec","version":1,"debugenabled":false,"service_domain":"media_player","service":"media_pause","entityId":"media_player.chromecast_vardagsrum","data":"{\"entity_id\": \"media_player.chromecast_vardagsrum\"}","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":790,"y":100,"wires":[["449e78d4.0a53d8"]]},{"id":"e6e436df.70c088","type":"switch","z":"94bc1df0.962d9","name":"","property":"payload","propertyType":"msg","rules":[{"t":"neq","v":"idle","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":210,"y":100,"wires":[["b5849cbd.9f008"]]},{"id":"b5849cbd.9f008","type":"api-current-state","z":"94bc1df0.962d9","name":"Andreas home","server":"4bbca37b.1700ec","version":1,"outputs":2,"halt_if":"HellBrant.*","halt_if_type":"re","halt_if_compare":"is","override_topic":false,"entity_id":"sensor.wifi_connection","state_type":"str","state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","blockInputOverrides":false,"x":360,"y":100,"wires":[["9b0e9110.ec516","d028c90.be62c38"],[]]},{"id":"2a0b2acd.322976","type":"trigger-state","z":"94bc1df0.962d9","name":"Petra","server":"4bbca37b.1700ec","exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityid":"sensor.petra_phone_state","entityidfiltertype":"exact","debugenabled":false,"constraints":[],"constraintsmustmatch":"all","outputs":2,"customoutputs":[],"outputinitially":false,"state_type":"str","x":50,"y":40,"wires":[["3b551083.553c2"],[]]},{"id":"3b551083.553c2","type":"switch","z":"94bc1df0.962d9","name":"","property":"payload","propertyType":"msg","rules":[{"t":"neq","v":"idle","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":210,"y":40,"wires":[["eb8939f5.c28cf8"]]},{"id":"eb8939f5.c28cf8","type":"api-current-state","z":"94bc1df0.962d9","name":"Petra home?","server":"4bbca37b.1700ec","version":1,"outputs":2,"halt_if":"HellBrant.*","halt_if_type":"re","halt_if_compare":"is","override_topic":false,"entity_id":"sensor.petra_wifi_connection","state_type":"str","state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","blockInputOverrides":false,"x":350,"y":40,"wires":[["d028c90.be62c38"],[]]},{"id":"d028c90.be62c38","type":"change","z":"94bc1df0.962d9","name":"","rules":[{"t":"set","p":"phone","pt":"msg","to":"topic","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":640,"y":100,"wires":[["43b5802.a9ea28"]]},{"id":"cb666d0a.f2c65","type":"api-current-state","z":"94bc1df0.962d9","name":"","server":"4bbca37b.1700ec","version":1,"outputs":2,"halt_if":"idle","halt_if_type":"str","halt_if_compare":"is_not","override_topic":false,"entity_id":"{{phone}}","state_type":"str","state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","blockInputOverrides":false,"x":1930,"y":500,"wires":[[],[]]},{"id":"4bbca37b.1700ec","type":"server","z":"","name":"Home Assistant","addon":true}]
I managed to find a way in case someone is trying to solve it now.
