Two time trigger, same cpu load ?!
have this two triggers the same cpu load?!
  - platform: time
    at: '10:00'
    value_template: "{{ is_state( 'sensor.time', '10:00' ) }}"
i’m studying HA and i know that using now() or a sensor.time will force the template to be evaluated every minute…
thanks
Both of them have such a low impact on CPU load that you don’t need to care about it.
Anyway I suggest the first one as it’s easier to read and will not be evaluated every minute as far as I know.
sorry, another doubt… i can’t use a template with at conditions of time triggers, so…
is it possible that HA can miss something like this
- wait_for_trigger:
or
- wait_for_trigger:
      value_template: "{{ now().strftime('%H:%M') == '10:00' }}"
thanks again
Sorry, but no
pnbruckner elucidated that time triggers (as the first) have to be evaluated ever second (as you could also set a time as ‘10:13:03’ so the second just does it 1/second
Acid test : - put it in the template editor and see what it says
Edit: I’m an idiot, you can’t test that
