I have trouble with my zigbee2mqtt-integrations. My setup is:
external server running docker compose with the following container:
- Host: zigbee2mqtt → CH 11, PAN ID 6754,
- Host zigbee2mqtt2 ->CH 25, PAN ID 6754
Mosquitto:
3. mosquitto mqtt-Server
Homeassitant is running on a different server.
My issue is, that I always loose devices from the zigbee2mqtt server in Homneassitant when I reboot the other zigbee2mqtt container. That means, that I alway have configured devices in HA from the last booted zigbee2mqtt container. Devices on both containers can be managed by the Web-Interface on the specific zigbee2mqtt-server.
To fix it in HA, I have to re-pair the devices from the missing container. Then both instances work smoothly until the next reboot of one of the zigbee2mqtt-servers
What is going wrong here? Do I need to change the PAN IDs to different IDs? And how can I change it? And what is the consequence if I change the id? Or can someone tell me how toI fix the issue?
here the configuration.yaml from both systems.
configuration1:
homeassistant:
legacy_entity_attributes: true
permit_join: false
mqtt:
base_topic: zigbee2mqtt
server: mqtt://mosquitto:8883
ca: /app/data/ssl/ca.crt
key: /app/data/ssl/zigbee2mqtt.key
cert: /app/data/ssl/zigbee2mqtt.crt
user: mqttService
password: xxxxxxx
serial: null
port: tcp://172.16.50.5:20108
keepalive: 60
reject_unauthorized: false
version: 4
serial:
frontend:
port: 8099
advanced:
log_syslog:
app_name: Zigbee2MQTT
eol: /n
host: localhost
localhost: localhost
path: /dev/log
pid: process.pid
port: 514
protocol: udp4
type: '5424'
timestamp_format: DD.MM.YYYY HH:mm:ss
channel: 25
homeassistant_legacy_entity_attributes: false
legacy_api: true
legacy_availability_payload: true
log_level: info
last_seen: ISO_8601_local
device_options:
legacy: false
configuration 2:
homeassistant:
permit_join: false
mqtt:
user: mqttService
password: xxxxxx
keepalive: 60
version: 4
serial:
port: tcp://172.16.50.7:6638
baudrate: 115200
frontend:
port: 8099
advanced:
log_syslog:
app_name: Zigbee2MQTT2
eol: /n
host: localhost
path: /dev/log
pid: process.pid
port: 514
protocol: udp4
type: '5424'
channel: 11
transmit_power: 20
legacy_api: true
log_level: info
device_options:
legacy: false
devices:
