Typed intent works but spoken does not
I am trying to implement a voice shopping list. What I’ve done so far responds correctly if I type the command into the assistant or if I speak it into the assist pop-up on my android phone app.
But, if I speak the command to my Voice Assistant PE it does not work. The Voice Assistant PE responds to the wake word and after I say the trigger and item “Add Eggs” for example. I get three quick blue flashed from the Voice Assistsnt PE light ring and nothing further happens.
Here’s what I have configured:
I found this blog post describing how to setup an intent and custom sentence. Adding shopping list items via Home Assistant voice commands
I added the intent to my configuration.yaml
# Voie Shopping List
conversation:
  intents: {}
intent_script:
  ShoppingListAddItem:
      action: todo.add_item
        entity_id: todo.shopping_list
        item: "{{ shop_item }}"
    speech:
      text: "{{ shop_item }} added to your shopping list."
and created a custom sentence file custom_sentences/en/shopping_list.yaml
language: "en"
intents:
      - sentences:
          - "Add {shop_item}"
lists:
  shop_item:
    wildcard: true
I only have one local Assist configured. I am using the Home Assistant conversation agent, and speech-to-phrase for the STT.
Do I need to do something additional to get the Voice Assistant PE unit to work with a custom intent and sentence like this?
Thanks!
Tom G.
I believe there’s now a built-in sentence to add items to the shopping list - could there be some conflict there?
Mine does this on one of them. What’s the debug logo the voice pipeline say for that device when it happens?
If so, then perhaps the issue I’m having with Voice Assistant PE was preventing the shopping list adds from working in the first place. Not knowing that was there I attempted the above solution. Time for further investigation…
I’m at work now but I will look at the debug logs this evening when I am back at home. Thanks!
Yeah my master bathroom vpe is dropping a LOT. It’ll start the voice response then… Stop.
I THINK it’s a connectivity issue to that device as it also has audio playback issues. The rest of mine (5) don’t do this. So it’s probably not the intent itself but the vpe.
I haven’t played with STP much, but my understanding is that has its own set of built-in sentences as well as customizations (See here for shopping list), which will differ from the regular built-in sentences that are used when one types in a text box or uses with a voice assistant that uses STT.
I presume you are putting your custom sentence under the ./configuration/, but for STP, the AddOn doc says:
  • You can add custom sentences to /share/speech-to-phrase/custom_sentences/<language>/sentences.yaml
Thanks!
A quick switch from Speech To Phrase to Fast Whisper proved the issue was with STT.
When on FW the Voice Assistant PE handles shopping list updates properly.
I added the custom sentence code to
share/speech-to-phrase/custom_sentences//sentences.yaml
and switched back to STT. But, no joy. I guess I have more readiing to do on STT customization…
What does the debug log show when it fails with Whisper?
My satisfaction with voice improved a lot when I started using Whisper Large Turbo. Unfortunately Large Turbo is too resource intensive to be offered as a standard option from within HA.
To clarify, it’s working with Fast Whisper. I turned on debug logging and spoke the sentence “Hey Jarvis, Add Eggs” Eggs appeared on the shopping list and here’s what showed in the log:
2025-03-21 14:47:05.908 DEBUG (MainThread) [aioesphomeapi.connection] home-assistant-voice-097259 @ 192.168.6.11: Sending VoiceAssistantEventResponse: event_type: VOICE_ASSISTANT_STT_VAD_END
2025-03-21 14:47:05.909 DEBUG (MainThread) [aioesphomeapi._frame_helper.base] home-assistant-voice-097259 @ 192.168.6.11: Sending frame: [00025c080c]
2025-03-21 14:47:08.484 DEBUG (MainThread) [aioesphomeapi.connection] home-assistant-voice-097259 @ 192.168.6.11: Sending VoiceAssistantEventResponse: event_type: VOICE_ASSISTANT_STT_END
data {
  value: " Add eggs"
2025-03-21 14:47:08.484 DEBUG (MainThread) [aioesphomeapi._frame_helper.base] home-assistant-voice-097259 @ 192.168.6.11: Sending frame: [00155c080412110a04746578741209204164642065676773]
2025-03-21 14:47:08.484 DEBUG (MainThread) [aioesphomeapi.connection] home-assistant-voice-097259 @ 192.168.6.11: Sending VoiceAssistantEventResponse: event_type: VOICE_ASSISTANT_INTENT_START
2025-03-21 14:47:08.484 DEBUG (MainThread) [aioesphomeapi._frame_helper.base] home-assistant-voice-097259 @ 192.168.6.11: Sending frame: [00025c0805]
2025-03-21 14:47:08.497 DEBUG (MainThread) [aioesphomeapi.connection] home-assistant-voice-097259 @ 192.168.6.11: Sending VoiceAssistantEventResponse: event_type: VOICE_ASSISTANT_INTENT_END
data {
  value: "01JPX08N7RJN7FHP5ETAWN3HHF"
2025-03-21 14:47:08.497 DEBUG (MainThread) [aioesphomeapi._frame_helper.base] home-assistant-voice-097259 @ 192.168.6.11: Sending frame: [00315c0806122d0a0f636f6e766572736174696f6e5f6964121a30314a505830384e37524a4e3746485035455441574e33484846]
2025-03-21 14:47:08.498 DEBUG (MainThread) [aioesphomeapi.connection] home-assistant-voice-097259 @ 192.168.6.11: Sending VoiceAssistantEventResponse: event_type: VOICE_ASSISTANT_TTS_START
data {
  value: "eggs added to your shopping list."
2025-03-21 14:47:08.498 DEBUG (MainThread) [aioesphomeapi._frame_helper.base] home-assistant-voice-097259 @ 192.168.6.11: Sending frame: [002d5c080712290a047465787412216567677320616464656420746f20796f75722073686f7070696e67206c6973742e]
2025-03-21 14:47:08.500 DEBUG (MainThread) [aioesphomeapi.connection] home-assistant-voice-097259 @ 192.168.6.11: Sending VoiceAssistantEventResponse: event_type: VOICE_ASSISTANT_TTS_END
data {
  value: "http://192.168.6.10:8123/api/tts_proxy/kLbsM507L_Gxiz2SWloczA.flac"
I switched back to Speech to Phrase and repeated the sentence. It either ignored me or mistakenly activated a scene. Here’s what I found in the log:
(I’m not sure how it got “activate Read scene” from me speaking the words “Add Eggs” but apparently it did…)
2025-03-21 14:56:13.562 DEBUG (MainThread) [aioesphomeapi.connection] home-assistant-voice-097259 @ 192.168.6.11: Sending VoiceAssistantEventResponse: event_type: VOICE_ASSISTANT_STT_VAD_END
2025-03-21 14:56:13.562 DEBUG (MainThread) [aioesphomeapi._frame_helper.base] home-assistant-voice-097259 @ 192.168.6.11: Sending frame: [00025c080c]
2025-03-21 14:56:13.946 DEBUG (MainThread) [aioesphomeapi.connection] home-assistant-voice-097259 @ 192.168.6.11: Sending VoiceAssistantEventResponse: event_type: VOICE_ASSISTANT_STT_END
data {
  value: "activate Read scene"
2025-03-21 14:56:13.946 DEBUG (MainThread) [aioesphomeapi._frame_helper.base] home-assistant-voice-097259 @ 192.168.6.11: Sending frame: [001f5c0804121b0a0474657874121361637469766174652052656164207363656e65]
2025-03-21 14:56:13.949 DEBUG (MainThread) [aioesphomeapi.connection] home-assistant-voice-097259 @ 192.168.6.11: Sending VoiceAssistantEventResponse: event_type: VOICE_ASSISTANT_INTENT_START
2025-03-21 14:56:13.949 DEBUG (MainThread) [aioesphomeapi._frame_helper.base] home-assistant-voice-097259 @ 192.168.6.11: Sending frame: [00025c0805]
2025-03-21 14:56:15.451 DEBUG (MainThread) [homeassistant.components.esphome.assist_satellite] Received unknown pipeline event type: intent-progress
2025-03-21 14:56:15.652 DEBUG (MainThread) [homeassistant.components.esphome.assist_satellite] Received unknown pipeline event type: intent-progress
2025-03-21 14:56:16.688 DEBUG (MainThread) [homeassistant.components.esphome.assist_satellite] Received unknown pipeline event type: intent-progress
2025-03-21 14:56:16.704 DEBUG (MainThread) [homeassistant.components.esphome.assist_satellite] Received unknown pipeline event type: intent-progress
2025-03-21 14:56:16.721 DEBUG (MainThread) [homeassistant.components.esphome.assist_satellite] Received unknown pipeline event type: intent-progress
2025-03-21 14:56:16.722 DEBUG (MainThread) [homeassistant.components.esphome.assist_satellite] Received unknown pipeline event type: intent-progress
2025-03-21 14:56:16.746 DEBUG (MainThread) [homeassistant.components.esphome.assist_satellite] Received unknown pipeline event type: intent-progress
2025-03-21 14:56:16.747 DEBUG (MainThread) [homeassistant.components.esphome.assist_satellite] Received unknown pipeline event type: intent-progress
2025-03-21 14:56:16.774 DEBUG (MainThread) [homeassistant.components.esphome.assist_satellite] Received unknown pipeline event type: intent-progress
2025-03-21 14:56:16.775 DEBUG (MainThread) [homeassistant.components.esphome.assist_satellite] Received unknown pipeline event type: intent-progress
2025-03-21 14:56:16.798 DEBUG (MainThread) [homeassistant.components.esphome.assist_satellite] Received unknown pipeline event type: intent-progress
2025-03-21 14:56:16.799 DEBUG (MainThread) [homeassistant.components.esphome.assist_satellite] Received unknown pipeline event type: intent-progress
2025-03-21 14:56:16.802 DEBUG (MainThread) [homeassistant.components.esphome.assist_satellite] Received unknown pipeline event type: intent-progress
2025-03-21 14:56:16.804 DEBUG (MainThread) [aioesphomeapi.connection] home-assistant-voice-097259 @ 192.168.6.11: Sending VoiceAssistantEventResponse: event_type: VOICE_ASSISTANT_INTENT_END
data {
2025-03-21 14:56:16.804 DEBUG (MainThread) [aioesphomeapi._frame_helper.base] home-assistant-voice-097259 @ 192.168.6.11: Sending frame: [00315c0806122d0a0f636f6e766572736174696f6e5f6964121a30314a505830384e37524a4e3746485035455441574e33484846]
2025-03-21 14:56:16.805 DEBUG (MainThread) [aioesphomeapi.connection] home-assistant-voice-097259 @ 192.168.6.11: Sending VoiceAssistantEventResponse: event_type: VOICE_ASSISTANT_TTS_START
data {
  value: "The Read scene in the Master Bedroom has been activated."
2025-03-21 14:56:16.805 DEBUG (MainThread) [aioesphomeapi._frame_helper.base] home-assistant-voice-097259 @ 192.168.6.11: Sending frame: [00445c080712400a047465787412385468652052656164207363656e6520696e20746865204d617374657220426564726f6f6d20686173206265656e206163746976617465642e]
2025-03-21 14:56:16.807 DEBUG (MainThread) [aioesphomeapi.connection] home-assistant-voice-097259 @ 192.168.6.11: Sending VoiceAssistantEventResponse: event_type: VOICE_ASSISTANT_TTS_END
data {
  value: "http://192.168.6.10:8123/api/tts_proxy/AgWgxjc4Vwu_9Qu89LzPIA.flac"
