TypeError run_at_sunset
Have a pretty simple automation:
import appdaemon.appapi as appapi
import datetime
class AutomateLights(appapi.AppDaemon):
    def initialize(self):
        self.run_at_sunset(self.lights_on, datetime.timedelta(minutes = -30).total_seconds(), "Sunset -30 mins")
    def lights_on(self, entity, attribute, old, new, kwargs):
        self.log("Turning on Lights: Sunset Triggered")
        for lights in self.split_device_list(self.args["lights"]):
            self.turn_on(lights)
When I save this I get this in the error.log?
2017-02-15 08:24:43.052500 WARNING ------------------------------------------------------------
2017-02-15 08:24:43.054204 WARNING Unexpected error:
2017-02-15 08:24:43.056351 WARNING ------------------------------------------------------------
2017-02-15 08:24:43.059134 WARNING Traceback (most recent call last):
  File "/usr/local/lib/python3.5/site-packages/appdaemon/appdaemon.py", line 938, in check_config
    new_config[name]["module"], new_config[name]
  File "/usr/local/lib/python3.5/site-packages/appdaemon/appdaemon.py", line 690, in init_object
    conf.objects[name]["object"].initialize()
  File "/home/pi/appdaemon/conf/apps/automate_lights.py", line 19, in initialize
TypeError: run_at_sunset() takes 2 positional arguments but 4 were given
2017-02-15 08:24:43.061160 WARNING ------------------------------------------------------------
Remove the string parameter “sunset -30 mins”
2017-02-15 15:12:46.361208 WARNING ------------------------------------------------------------
2017-02-15 15:12:46.362196 WARNING Unexpected error during loading of Living Room Lights:
2017-02-15 15:12:46.363467 WARNING ------------------------------------------------------------
2017-02-15 15:12:46.367132 WARNING Traceback (most recent call last):
File “/usr/local/lib/python3.5/site-packages/appdaemon/appdaemon.py”, line 996, in read_app
init_object(name, class_name, module_name, config[name])
File “/usr/local/lib/python3.5/site-packages/appdaemon/appdaemon.py”, line 690, in init_object
conf.objects[name][“object”].initialize()
File “/home/pi/appdaemon/conf/apps/automate_lights.py”, line 19, in initialize
self.run_at_sunset(self.lights_on, datetime.timedelta(minutes = -30).total_seconds())
TypeError: run_at_sunset() takes 2 positional arguments but 3 were given
Whoops! Looks like I was missing
offset =
Should be:
offset = datetime.timedelta(minutes = -30).total_seconds()
it is missing in the API example :wink:
i changed it in the API and made a pullrequest for it @aimc
Thanks Rene :slight_smile:
