However, be extremely careful since those relays are only rated at 10A. That is almost certainly below what your towel dryer will pull, and probably also too low for your air vent.
You need something with a relay Amp rating that is at least 25% greater than what your heater will pull, and more like 50% for the motor on your air vent.
What I was trying to achieve was just to reuse a set of wires I have in my bathroom from the regular switch. This set was initially designed for venting, but without speed switching. I’ve installed a double-speed vent now.
I want to reuse this manual switch as a signalling device for the relay, and HA can use this signal to start the vent on speed 1 or turn it off, etc.
The schematic is in Ukrainian, but the devices are still recognisable =)
As I understand, this is a bad idea to rely only on internal relays. I can use a proper “contactor” from Schneider, for example. With a contactor, I can separate the actual load of 10A+ and the logical relay from Tuya. Tuya will only trigger the contactor, and this should be fine, am I correct?
You’re right. Seems like you’ll only be switching 10% of the rated relay load, so you should be fine without a contactor.
However, I did some more digging on that model and there’s 2 things you need to be aware of:
If you’re using Z2M, you might need a quirk because the model numbers in your link differ by one letter. Your link’s model number ends in B1RF, while the supported device in Z2M ends in D1RF. Should be a pretty simple thing to fix.
More importantly, there’s a huge warning on that Z2M page:
The device has a potentially deathly flaw.
The mains power supply is based on a simple buck converter where neutral of the mains input is referencing GND on the sensor connector.
This device should only be powered by an isolated power supply via the micro-USB port.
Given you intend to use the T&H sensor on it and that it will potentially be in a bathroom, you can imagine that things might get extremely dangerous.
Personally, I would suggest not using the sensor at all and getting a separate zigbee T&H sensor for your bathroom.
Yeah, your wireless t&h sensor will be much safer for the bathroom.
If my answer helped answer your question, please consider marking my post above with the Solution tag. This will automatically place a check-mark next to the topic’s title which signals to other users that this topic has been resolved and helps users find answers to similar questions.
The main idea seems incorrect in the part from the pic, where switch is used as signalling device. Since there is a DC, not an AC setup at the example.
The short answer is: I still do not understand what this switch will do even in a 5V setup.
Maybe 5V into COM is not enough for such a relay to operate independently. As I recall from the “interlock” setup, the relay should change its state as soon as it receives some voltage at COM.
So there is a possibility to “signal” into the relay from the regular switch.
Tested it again, the code is not using software interlock, just a hardware at the relay.
