Ubuntu docker: Unable to connect to Home Assistant. Retry
In Chrome, where I normally log in, I get the classic “Unable to connect to Home Assistant. Retry” message. From incognito or Edge, I don’t even get that, but a standard “This site can’t be reached” page. Running in a docker container on Ubuntu, using duckdns.
I don’t know much about debugging HA from outside HA. I can remote into the computer just fine, but that’s it.
Tips on where to start?
look at the home-assistant.log file in the config directory for errors.
If you are running docker try docker ps to see if the container is running.
What was the docker commandline that you used to run home assistant?
Oof, I feel dumb.
home-assistant.log said one of my secrets wasn’t found. Turns out I commented one out without checking that it wasn’t used anywhere anymore.
Thanks darksky.
We’ve all been there.
Just make sure you always do a config check before restarting to catch those errors.
