I had 1 blissful week with Home Assistant until it came crashing down (without me doing anything major ;( )
Issue Summary
- Running Home Assistant OS on Raspberry Pi (32GB SD card, ~20GB free).
- System had been running ~1 week without major issues.
- Attempted a Home Assistant update.
- After update attempt, UI became stuck on “Loading data” screen.
- Automations continued to work in the background (lights still respond).
http://<ip>:8123/api/returns401 Unauthorized(backend responding).- Supervisor/Observer shows:
- Supervisor: Connected
- Health: Healthy
- Support: Supported
What I Have Tried
- Restarted Home Assistant.
- Full power cycle (waited before rebooting).
- Cleared browser cache / private mode.
- Removed
home-assistant_v2.db(recorder DB) — no change. - Reflashed fresh HA OS.
- Restored full backup (encrypted, key available).
- Restored oldest available backup.
- Result after restore: same “Loading data” freeze.
Fresh install without restoring works normally.
This suggests the issue is reproducible from backup and likely configuration-level.
Environment Notes
- Not disk full (20GB free).
- No major YAML experimentation that I recall.
- Possibly installed a small editor-related add-on before update.
- Dashboard appears to be YAML mode (saw
lovelace.map, not JSON lovelace file). - No custom HACS-heavy setup.
Concern
At this early stage (only ~1 week in), I am already facing a full rebuild scenario:
- 20+ devices to reconfigure
- Renaming rooms and entities again
- Rebuilding automations
- Losing history
- Re-pairing Zigbee if necessary
This raises concern about reliability and update safety.
I’m unsure whether this was caused by something I did, a breaking change, or a migration bug. I would prefer not to rebuild from scratch unless absolutely necessary.
If useful, I can provide:
- Backup structure contents
configuration.yaml- List of integrations in use
- Exact version I updated from/to
