UI does not start
Hello HA community,
I’m not so new on HA, since I used it for 3 year now and I absolutly love this <3
But now I’m having trouble and I summon the community help !
I running Hassio on RasPi 3B, and I yesterday upgrade from 100.1 to 103.3
But after the upgrade I can not access to the HMI. I still have access to HA via SSH or Samba, check the logs, change the configuration, but the HMI (and all HA I think) does not start. I wonder why.
I checked logs, read many discussions on this forum, docs, webpages… but it can’t help.
Does anybody have a clue ?
core-ssh:/config# cat home-assistant.log
2019-12-23 09:50:18 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for spotcast which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2019-12-23 09:50:18 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2019-12-23 09:50:19 INFO (MainThread) [homeassistant.setup] Setup of domain logger took 0.0 seconds.
2019-12-23 09:50:19 INFO (MainThread) [homeassistant.setup] Setting up http
2019-12-23 09:50:19 INFO (MainThread) [homeassistant.setup] Setup of domain http took 0.0 seconds.
2019-12-23 09:50:19 INFO (MainThread) [homeassistant.setup] Setting up system_log
2019-12-23 09:50:19 INFO (MainThread) [homeassistant.setup] Setup of domain system_log took 0.0 seconds.
2019-12-23 09:50:20 INFO (MainThread) [homeassistant.setup] Setting up recorder
2019-12-23 09:50:21 WARNING (Recorder) [homeassistant.components.recorder] Ended unfinished session (id=147 from 2019-12-23 08:45:33.093008)
2019-12-23 09:50:21 INFO (MainThread) [homeassistant.setup] Setup of domain recorder took 0.6 seconds.
2019-12-23 09:50:21 INFO (MainThread) [homeassistant.setup] Setting up sun
2019-12-23 09:50:21 INFO (MainThread) [homeassistant.setup] Setup of domain sun took 0.1 seconds.
2019-12-23 09:50:21 INFO (SyncWorker_5) [homeassistant.loader] Loaded template from homeassistant.components.template
2019-12-23 09:50:22 INFO (MainThread) [homeassistant.setup] Setting up nest
2019-12-23 09:50:22 INFO (MainThread) [homeassistant.setup] Setup of domain nest took 0.0 seconds.
2019-12-23 09:50:22 INFO (MainThread) [homeassistant.setup] Setting up lovelace
2019-12-23 09:50:22 INFO (MainThread) [homeassistant.setup] Setup of domain lovelace took 0.0 seconds.
2019-12-23 09:50:22 INFO (SyncWorker_1) [homeassistant.loader] Loaded nfandroidtv from homeassistant.components.nfandroidtv
2019-12-23 09:50:23 INFO (MainThread) [homeassistant.setup] Setting up discovery
2019-12-23 09:50:23 INFO (MainThread) [homeassistant.setup] Setup of domain discovery took 0.0 seconds.
2019-12-23 09:50:23 INFO (MainThread) [homeassistant.setup] Setting up zone
2019-12-23 09:50:23 INFO (MainThread) [homeassistant.setup] Setup of domain zone took 0.0 seconds.
2019-12-23 09:50:23 INFO (MainThread) [homeassistant.setup] Setting up group
2019-12-23 09:50:23 INFO (SyncWorker_19) [homeassistant.loader] Loaded manual from homeassistant.components.manual
2019-12-23 09:50:23 INFO (MainThread) [homeassistant.setup] Setting up scene
2019-12-23 09:50:23 INFO (SyncWorker_11) [homeassistant.loader] Loaded generic_thermostat from homeassistant.components.generic_thermostat
2019-12-23 09:50:23 INFO (SyncWorker_18) [homeassistant.loader] Loaded darksky from homeassistant.components.darksky
2019-12-23 09:50:23 INFO (MainThread) [homeassistant.setup] Setting up person
2019-12-23 09:50:23 INFO (MainThread) [homeassistant.setup] Setting up tuya
2019-12-23 09:50:23 INFO (MainThread) [homeassistant.setup] Setting up input_boolean
2019-12-23 09:50:24 INFO (MainThread) [homeassistant.setup] Setting up spotcast
2019-12-23 09:50:24 INFO (MainThread) [homeassistant.setup] Setting up rflink
2019-12-23 09:50:24 INFO (MainThread) [homeassistant.setup] Setup of domain rflink took 0.0 seconds.
2019-12-23 09:50:24 INFO (MainThread) [homeassistant.setup] Setting up speedtestdotnet
2019-12-23 09:50:24 INFO (MainThread) [homeassistant.setup] Setup of domain speedtestdotnet took 0.0 seconds.
2019-12-23 09:50:24 INFO (MainThread) [homeassistant.setup] Setting up input_select
2019-12-23 09:50:24 INFO (MainThread) [homeassistant.setup] Setting up shell_command
2019-12-23 09:50:24 INFO (MainThread) [homeassistant.setup] Setup of domain shell_command took 0.0 seconds.
2019-12-23 09:50:24 INFO (MainThread) [homeassistant.setup] Setting up updater
2019-12-23 09:50:24 INFO (MainThread) [homeassistant.components.scene] Setting up scene.homeassistant
2019-12-23 09:50:24 INFO (MainThread) [homeassistant.components.rflink] Initiating Rflink connection
2019-12-23 09:50:24 INFO (MainThread) [homeassistant.components.rflink] Connected to Rflink
2019-12-23 09:50:25 INFO (SyncWorker_3) [homeassistant.loader] Loaded time_date from homeassistant.components.time_date
2019-12-23 09:50:25 INFO (SyncWorker_5) [homeassistant.loader] Loaded pushbullet from homeassistant.components.pushbullet
2019-12-23 09:50:25 INFO (MainThread) [homeassistant.setup] Setting up alarm_control_panel
2019-12-23 09:50:25 INFO (MainThread) [homeassistant.setup] Setting up weather
2019-12-23 09:50:25 DEBUG (MainThread) [rflink.protocol] connected
2019-12-23 09:50:25 INFO (SyncWorker_1) [homeassistant.loader] Loaded binary_sensor from homeassistant.components.binary_sensor
2019-12-23 09:50:25 INFO (SyncWorker_19) [homeassistant.loader] Loaded universal from homeassistant.components.universal
2019-12-23 09:50:25 INFO (MainThread) [homeassistant.setup] Setting up config
2019-12-23 09:50:25 INFO (MainThread) [homeassistant.setup] Setting up conversation
2019-12-23 09:50:25 INFO (MainThread) [homeassistant.setup] Setup of domain conversation took 0.0 seconds.
2019-12-23 09:50:25 INFO (MainThread) [homeassistant.setup] Setting up websocket_api
2019-12-23 09:50:25 INFO (MainThread) [homeassistant.setup] Setup of domain websocket_api took 0.0 seconds.
2019-12-23 09:50:25 INFO (MainThread) [homeassistant.setup] Setting up api
2019-12-23 09:50:25 INFO (MainThread) [homeassistant.setup] Setting up system_health
2019-12-23 09:50:25 INFO (MainThread) [homeassistant.setup] Setup of domain system_health took 0.0 seconds.
2019-12-23 09:50:25 INFO (MainThread) [homeassistant.setup] Setting up history
2019-12-23 09:50:25 INFO (MainThread) [homeassistant.setup] Setup of domain history took 0.0 seconds.
2019-12-23 09:50:25 INFO (MainThread) [homeassistant.components.alarm_control_panel] Setting up alarm_control_panel.manual
2019-12-23 09:50:25 INFO (MainThread) [homeassistant.setup] Setup of domain updater took 0.8 seconds.
2019-12-23 09:50:25 INFO (MainThread) [homeassistant.components.weather] Setting up weather.darksky
2019-12-23 09:50:25 INFO (MainThread) [homeassistant.setup] Setting up webhook
2019-12-23 09:50:25 INFO (MainThread) [homeassistant.setup] Setup of domain webhook took 0.0 seconds.
2019-12-23 09:50:25 INFO (MainThread) [homeassistant.setup] Setup of domain spotcast took 1.7 seconds.
2019-12-23 09:50:26 INFO (SyncWorker_12) [homeassistant.loader] Loaded synologydsm from homeassistant.components.synologydsm
2019-12-23 09:50:28 INFO (MainThread) [homeassistant.setup] Setting up notify
2019-12-23 09:50:28 INFO (MainThread) [homeassistant.setup] Setup of domain person took 4.9 seconds.
2019-12-23 09:50:28 INFO (MainThread) [homeassistant.setup] Setting up auth
2019-12-23 09:50:28 INFO (MainThread) [homeassistant.setup] Setup of domain auth took 0.0 seconds.
2019-12-23 09:50:28 INFO (MainThread) [homeassistant.setup] Setting up binary_sensor
2019-12-23 09:50:28 INFO (MainThread) [homeassistant.setup] Setup of domain binary_sensor took 0.0 seconds.
2019-12-23 09:50:28 INFO (MainThread) [homeassistant.setup] Setup of domain api took 3.1 seconds.
2019-12-23 09:50:28 INFO (SyncWorker_4) [homeassistant.loader] Loaded spotify from homeassistant.components.spotify
2019-12-23 09:50:28 INFO (MainThread) [homeassistant.components.notify] Setting up notify.pushbullet
2019-12-23 09:50:28 INFO (MainThread) [homeassistant.components.notify] Setting up notify.nfandroidtv
2019-12-23 09:50:28 INFO (MainThread) [homeassistant.setup] Setup of domain config took 3.3 seconds.
2019-12-23 09:50:28 INFO (SyncWorker_8) [homeassistant.loader] Loaded google_translate from homeassistant.components.google_translate
2019-12-23 09:50:29 INFO (MainThread) [homeassistant.setup] Setting up device_automation
2019-12-23 09:50:29 INFO (MainThread) [homeassistant.setup] Setup of domain device_automation took 0.0 seconds.
2019-12-23 09:50:29 INFO (SyncWorker_1) [homeassistant.loader] Loaded systemmonitor from homeassistant.components.systemmonitor
2019-12-23 09:50:30 INFO (MainThread) [homeassistant.setup] Setting up mqtt
2019-12-23 09:50:30 INFO (MainThread) [homeassistant.setup] Setup of domain mqtt took 0.0 seconds.
2019-12-23 09:50:30 INFO (MainThread) [homeassistant.setup] Setting up onboarding
2019-12-23 09:50:30 INFO (MainThread) [homeassistant.components.binary_sensor] Setting up binary_sensor.updater
2019-12-23 09:50:30 INFO (MainThread) [homeassistant.setup] Setting up tts
2019-12-23 09:50:30 INFO (SyncWorker_7) [homeassistant.loader] Loaded configurator from homeassistant.components.configurator
2019-12-23 09:50:30 INFO (MainThread) [homeassistant.setup] Setting up climate
2019-12-23 09:50:30 INFO (MainThread) [homeassistant.setup] Setup of domain tuya took 6.9 seconds.
2019-12-23 09:50:31 INFO (MainThread) [homeassistant.components.scene] Setting up scene.homeassistant
2019-12-23 09:50:31 INFO (MainThread) [homeassistant.helpers.storage] Migrating onboarding storage from 1 to 3
2019-12-23 09:50:31 INFO (MainThread) [homeassistant.setup] Setup of domain notify took 3.3 seconds.
2019-12-23 09:50:31 INFO (MainThread) [homeassistant.setup] Setting up media_player
2019-12-23 09:50:31 INFO (MainThread) [homeassistant.setup] Setup of domain onboarding took 1.5 seconds.
2019-12-23 09:50:31 INFO (MainThread) [homeassistant.setup] Setup of domain input_boolean took 8.2 seconds.
2019-12-23 09:50:31 INFO (MainThread) [homeassistant.setup] Setup of domain input_select took 7.2 seconds.
2019-12-23 09:50:31 INFO (MainThread) [homeassistant.components.media_player] Setting up media_player.universal
2019-12-23 09:50:31 INFO (MainThread) [homeassistant.setup] Setup of domain scene took 8.5 seconds.
2019-12-23 09:50:32 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for rpi_power which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2019-12-23 09:50:32 INFO (MainThread) [homeassistant.setup] Setting up sensor
2019-12-23 09:50:32 INFO (MainThread) [homeassistant.setup] Setup of domain weather took 6.6 seconds.
2019-12-23 09:50:32 INFO (MainThread) [homeassistant.setup] Setting up configurator
2019-12-23 09:50:32 INFO (MainThread) [homeassistant.setup] Setup of domain configurator took 0.0 seconds.
2019-12-23 09:50:32 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.mqtt
2019-12-23 09:50:32 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.darksky
2019-12-23 09:50:32 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.time_date
2019-12-23 09:50:32 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.template
2019-12-23 09:50:32 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.rpi_power
2019-12-23 09:50:32 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.synologydsm
2019-12-23 09:50:32 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.systemmonitor
2019-12-23 09:50:32 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.rflink
2019-12-23 09:50:32 INFO (MainThread) [homeassistant.setup] Setup of domain tts took 2.5 seconds.
2019-12-23 09:50:32 INFO (MainThread) [homeassistant.setup] Setup of domain alarm_control_panel took 7.6 seconds.
2019-12-23 09:50:33 INFO (MainThread) [homeassistant.setup] Setup of domain group took 9.8 seconds.
2019-12-23 09:50:33 INFO (SyncWorker_12) [homeassistant.loader] Loaded xiaomi_miio from homeassistant.components.xiaomi_miio
2019-12-23 09:50:33 INFO (SyncWorker_2) [homeassistant.loader] Loaded nmap_tracker from homeassistant.components.nmap_tracker
2019-12-23 09:50:33 INFO (SyncWorker_7) [homeassistant.loader] Loaded yeelight from homeassistant.components.yeelight
2019-12-23 09:50:33 INFO (MainThread) [homeassistant.setup] Setting up script
2019-12-23 09:50:34 INFO (MainThread) [homeassistant.components.media_player] Setting up media_player.spotify
2019-12-23 09:50:36 INFO (MainThread) [homeassistant.setup] Setting up vacuum
2019-12-23 09:50:36 INFO (MainThread) [homeassistant.setup] Setting up device_tracker
2019-12-23 09:50:37 INFO (MainThread) [homeassistant.setup] Setting up light
2019-12-23 09:50:37 INFO (MainThread) [homeassistant.components.vacuum] Setting up vacuum.xiaomi_miio
2019-12-23 09:50:37 INFO (MainThread) [homeassistant.setup] Setting up automation
2019-12-23 09:50:37 INFO (MainThread) [homeassistant.components.light] Setting up light.rflink
2019-12-23 09:50:37 INFO (MainThread) [homeassistant.setup] Setup of domain script took 3.9 seconds.
2019-12-23 09:50:37 INFO (MainThread) [homeassistant.setup] Setting up switch
2019-12-23 09:50:37 INFO (MainThread) [homeassistant.setup] Setting up cover
2019-12-23 09:50:37 INFO (MainThread) [homeassistant.setup] Setting up frontend
2019-12-23 09:50:37 INFO (MainThread) [homeassistant.setup] Setup of domain frontend took 0.0 seconds.
2019-12-23 09:50:37 INFO (MainThread) [homeassistant.components.xiaomi_miio.vacuum] Initializing with host 192.168.1.72 (token 71326...)
2019-12-23 09:50:37 INFO (MainThread) [homeassistant.setup] Setting up yeelight
2019-12-23 09:50:37 INFO (MainThread) [homeassistant.components.switch] Setting up switch.mqtt
2019-12-23 09:50:37 INFO (MainThread) [homeassistant.components.switch] Setting up switch.rflink
2019-12-23 09:50:38 INFO (MainThread) [homeassistant.components.switch] Setting up switch.template
2019-12-23 09:50:38 INFO (MainThread) [homeassistant.components.switch] Setting up switch.rflink
2019-12-23 09:50:38 INFO (MainThread) [homeassistant.components.cover] Setting up cover.mqtt
2019-12-23 09:50:38 INFO (MainThread) [homeassistant.components.cover] Setting up cover.template
2019-12-23 09:50:38 INFO (MainThread) [homeassistant.setup] Setting up panel_custom
2019-12-23 09:50:38 INFO (MainThread) [homeassistant.setup] Setup of domain panel_custom took 0.0 seconds.
2019-12-23 09:50:38 INFO (SyncWorker_1) [homeassistant.components.spotify.media_player] New Devices: {'Web Player (Chrome)': '1601fbdb200c6ad1ea0ec4b0d19671ac5b7fda11', 'Salon': '9354e99ae90532c978888b763005368e'}
2019-12-23 09:50:38 INFO (SyncWorker_18) [homeassistant.util.package] Attempting install of attrs==19.2.0
2019-12-23 09:50:38 INFO (MainThread) [homeassistant.components.device_tracker] Setting up device_tracker.legacy
2019-12-23 09:50:38 INFO (MainThread) [homeassistant.setup] Setup of domain automation took 1.4 seconds.
2019-12-23 09:50:38 INFO (MainThread) [homeassistant.setup] Setup of domain yeelight took 0.7 seconds.
2019-12-23 09:50:38 INFO (MainThread) [homeassistant.setup] Setting up hassio
2019-12-23 09:50:38 INFO (MainThread) [homeassistant.components.light] Setting up light.yeelight
2019-12-23 09:50:38 INFO (MainThread) [homeassistant.setup] Setup of domain cover took 1.0 seconds.
2019-12-23 09:50:38 INFO (MainThread) [homeassistant.setup] Setup of domain device_tracker took 2.2 seconds.
2019-12-23 09:50:38 INFO (MainThread) [homeassistant.setup] Setup of domain switch took 1.0 seconds.
2019-12-23 09:50:38 INFO (MainThread) [homeassistant.components.switch] Setting up switch.tuya
2019-12-23 09:50:38 INFO (MainThread) [homeassistant.setup] Setup of domain light took 1.8 seconds.
2019-12-23 09:50:38 INFO (MainThread) [homeassistant.setup] Setup of domain media_player took 7.3 seconds.
2019-12-23 09:50:39 INFO (MainThread) [homeassistant.setup] Setup of domain sensor took 7.0 seconds.
2019-12-23 09:50:39 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.speedtestdotnet
2019-12-23 09:50:39 INFO (MainThread) [homeassistant.components.climate] Setting up climate.generic_thermostat
2019-12-23 09:50:39 INFO (MainThread) [homeassistant.setup] Setup of domain climate took 8.9 seconds.
2019-12-23 09:50:39 INFO (MainThread) [homeassistant.setup] Setup of domain hassio took 0.7 seconds.
2019-12-23 09:50:43 INFO (MainThread) [homeassistant.setup] Setup of domain vacuum took 7.1 seconds.
Thanks in advance,
Is there any other logs sources to check ?
How can I rollback without having access to the HMI ? (by editing a file, maybe ?)
I had to google for the term HMI.
If you have samba or SSH access to your HA : rename your configuration.yam to something else. Reboot HA. Then one at a time fill back your configuration.yaml
Try to disable your custom components? See your warnings.
Damn, you’re right, removing all customs components works !
I thought those warning were just indication about executing external components (ie legal stuff…)
Thank you very much !!!
