This is a ping binary sensor for one of my hosts:
The ‘More Info’ UI is showing the correct connected time, when this host came online, i.e. 15:32:41 local time.
But the last_changed attribute for this sensor is showing a completely different time, i.e. 16:37:06 UTC, which would translate to 18:37:06 local time:
According to the documentation the last_changed attribute contains the timestamp of the last change of the sensor’s state. As the UI is showing the correct time, I’d expect the last_changed attribute of the sensor showing the same time (in UTC). But obviously its off by about 3 hours, 4 minutes and a couple of seconds.
How can this difference be explained and where does the UI get the correct value from?
