Hi all I’m looking for a water meter and shutoff valve to monitor usage and allow me to automatically shut off supply. Requirements are…
Integrate with Home Assistant (Naturally :))
Compatible with UK plumbing. I don’t mind if it needs plumber installation.
Measure accurate consumption values that can be used with energy dashboard.
Allow automatic shutoff (Not critical but preferred)
Local control (No cloud API)
It looks like the Moen Flo is ideal hardware wise but the cloud requirement (and price) puts me off.
For water metering only I considered going the ESPcam approach to read the existing utility company meter dials but unfortunately the meter is some distance from the house in the underground utility provider duct and wiring to it will not be easily possible.
If you’re using Zigbee and have a decent mesh going in the area where you’d like to install it, support for a water meter/valve device meeting all your requirements has just been added in Z2M’s latest release. It’s available from Zemismart, who mention it’s also compatible with ZHA in the second pic.
I had to pass on it because installation requirements are too restrictive for my situation. Also, the fact that it’s battery powered had me worried a bit, but it seems the water flow recharges the battery (at least this Amazon listing says it’s hydraulic powered).
Watch out if you intend to get that. Judging by the pics you posted earlier, you might not have the necessary clearance to install it properly. EDIT: those weren’t your pics, sorry.
Their Installation Requirements mention a straight run of 10x pipe length on the inlet and 5x pipe length on the outlet. I’m not really sure what exactly they’re referring to for the multiplier. Is it 10x the pipe width? The meter length? Your shoe size?
I would also ask them to clarify what they mean about that in your message. Eg. In their own doc, M1 matches their installation description (inlet length looks sufficient), but M2 doesn’t (inlet length looks quite short compared to the outlet).
If you think you have a decent enough section of straight pipe where the installation requirements don’t really affect you, go for it. Otherwise, keep waiting for a reply before dropping >100 bucks on something which won’t work in your situation.
Quote:
-The installation shown in M-1 is correct, the meter is mounted low in the pipe, there is back pressure at the back end of the meter, and no air bubbles are generated that would affect the accuracy of the measurement, this is a horizontal installation.
-The installation shown in M-2 is correct, and this mounting position also does not generate air bubbles for the same reason as A. This figure shows a vertical installation.
-The installation shown in M-3 is incorrect, as the meter is mounted high in the pipe, where air bubbles tend to accumulate and affect measurement accuracy.
-The installation shown in M-4 is incorrect. This installation is a vertical installation with a downward water inlet, which is not allowed.
I have just ordered the Zemismart one, may be a couple of months before it can be installed.
We have a private water borehole and no current way to measure consumption.
When they come to service the filtration system, I will get them to install the meter.
I have to assume the multiples before and after are to do with the pipe diameter, I can’t see what else it could be.
