UK Zigbee Relay for 3-way Light (incl dimming)
Struggling to find this exact scenario when searching, so thought best to ask for some guidance/recommendations.
In essence I have a pair of lights in an entrance hallway that I’d like to get under HA control. These lights (together) are controlled by a 3-way set of light switches. I’m thinking that a relay will be the best option, providing it’s small enough that I can get it into one of the backboxes. I already have zigbee, the controller and ZHA up and running for other purposes, so I’d prefer to leverage that as opposed to wifi/bluetooth options. Some light research turns up the Sonoff ZBmini, but I’m unclear if this is a good option given the parameters above, or if something else would be better? I could replace one of the switches with a zigbee switch, but suspect a 3-way configuration with dimming would be complex.
Fwiw, it’s a UK new build house (built 2024). I’m also happy to get an electrician to do the install, but want to either buy or instruct what kit should be used.
Thanks in advance for any input.
