I’m currently setting up an Ulanzi TC100, flashed with Awtrix 3 via MQTT, as a display with Home Assistant. So far, it’s working quite well.
Now I’ve reached a point where I actually need two icons – which doesn’t seem to be possible.
So I’ve thought of displaying several apps, each with one of the icons, in succession for one second at a time.
That basically solves my problem. ![]()
- id: "1782540001001"
alias: AWTRIX 001 - App TEMPSELF
description: AWTRIX App TEMPSELF zeigt die vom AWTRIX selbst gemessene Temperatur in mehreren kurzen Apps
mode: single
triggers:
- trigger: state
entity_id: sensor.awtrix_2f2334_temperature
- trigger: homeassistant
event: start
actions:
- variables:
temp: "{{ states('sensor.awtrix_2f2334_temperature') | float(none) }}"
temp_text: >-
{% if temp is none %}
FEHLER
{% else %}
{{ temp | round(1) }} °
{% endif %}
icon_temp: "52864"
icon_arrow: "6588"
- action: mqtt.publish
topic: awtrix_tc001_01/custom/TEMPSELF1
retain: true
payload: >-
"icon": "{{ icon_temp }}",
"text": "{{ temp_text }}",
"duration": 1,
"noScroll": true,
"pushIcon": 2
topic: awtrix_tc001_01/custom/TEMPSELF2
retain: true
payload: >-
"icon": "{{ icon_arrow }}",
"duration": 1,
"noScroll": true,
"pushIcon": 2
What bothers me is that the apps fade into one another one after the other (‘transition’). Unfortunately, I haven’t yet found a way to control the transition for individual apps; I’ve only found a global setting.
Is there a solution? A workaround?
Best regards ![]()
Andreas
