The readings were very stable. Since I have moved to another setup over NMEA2k but I also tried the UART one. Could not get it to work for some reason.
Code for a02yyuw UART controlled. You could play with filters if needed.
uart:
rx_pin: 20 # ESP32 C3 super mini
# tx_pin: 21 # ESP32 C3 super mini used by switch to trigger
baud_rate: 9600
- platform: a02yyuw
id: a02yyuw_sensor # UART Controlled
unit_of_measurement: 'm'
accuracy_decimals: 2
filters:
- multiply: 0.001
# - throttle: 5s
# - heartbeat: 5s
# - quantile:
# window_size: 7
# send_every: 4
# send_first_at: 3
# quantile: .9
# - debounce: 0.1s
switch:
- platform: gpio
pin: GPIO21
internal: true
interval:
- interval: 3s
then:
- switch.turn_on: GPIO21_switch
- delay: 100ms
- switch.turn_off: GPIO21_switch
- delay: 50ms
