Unable to access home assistant - ERR_EMPTY_RESPONSE
Hi, I just installed Hassio and it worked fine. Then I configured these addons: configurator, mosquitto broker, duckdns.
I was configuring my router for duckdns opening port 8123 but something went wrong. I had to reset my router. So I reset everything in my router, including the reserved ip address for the raspberry PI.
when I do hassio.local:8123 or my.ip.address:8123 the browser doesn’t connect.
I checked and the device is actually connected to the router and I ping it and it works.
I cannot access my home assistant now and did not installed ssh. I get ERR_EMPTY_RESPONSE
I can connect to my configurator via http://hassio.local:3218/
How can I access hassio? How do I fix this problem?
Thank you
Alessandro
Since the router lost the reservation for hassio, it may have assigned a different ip address.
Many routers that are also DHCP servers are able to show either what leases were assigned or what clients are active on the network
I confirm that my router is assigning the internal ip correctly (192.168.0.8 as I assigned before)
If I go in the router I see IP:192.168.0.8 ASSIGNED TO: Hassio
In fact I can access 192.168.0.8:3218
So why can’t I access the home assistant dashboard with 192.168.0.8:8123 ??
Any Idea of what I can do to fix this?
Thank you
I am not sure how, but I managed to fix it. Now I can enter the dashboard. Thanks for your help!
Hello, I have the same issue :
I moved my HA from my mum’s home to mine, the public IP was automatically updated by HA on DuckDNS - however I’m not able to access it in both local or internet with both the companion app and Duckduckgo.
I opened the ports and made a reservation for HA with its MAC address I found on the router. I can only access the HA from its command panel with hdmi, so it’s kinda hard to check the configurations.
