Unable to add Broadlink integration
When I select configuration the add integration, Broadlink is not available. What am I missing ?
TIA
what version of HA are you on?
I’m pretty sure the UI integration for Broadlink was added in V115. If you are on a version previous to that you will have to add it manually in your configuration.yaml.
Considering the release for Version 0.115 just released, I’m presuming you probably just need to update.
Thanks everyone. Must have screwed update. Can no longer log in, w default admin/admin or the password I had changed to. Uninstalled the installed, same issue
