Unable to add forecast solar integration as forecast if not adding energy source at same time
Wondering if it supposed to work in the energy dashboard to add forecast.solar you have to remove the solar energy and then always add the forecast with the energy data - because this is what I just had to do and seems it has been this way for some time (maybe? or previously fixed?? or works as it should??)
I have not found a report of the issue.
strangely, I think, this “feature” is not documented in any way that I have found in either forecast.solar or energy and I guess it would probably help users like me if there was at least some indication in the drop down when adding that it must be added with the energy source instead of just a grayed out save button, but maybe it is just me :slight_smile:
That is not the case. When you have configured the pv entity you can always edit the forecast setting.
That is because you havent configured a pv enitity. If you only want the forecast, use a template sensor.
