Hi everyone, I was wondering if someone could explain why I can no longer add my home assistant to Google Home. Everything used to work back in September 2022 when I initially set up the integration but now I cannot log into the ‘Works with Google’ integration. I’m not using Nabu Casa and instead followed Everything Smart Home’s tutorial. I also use a Cloudflare URL to access my Home Assistant instead of forwarding ports.
I set everything up in Google Actions and Google Console and when I click on ‘Works with Google’ to add the devices, I get the Home Assistant login screen as I should do. However, when I try and log in (using 1Password) I get an invalid username or password error. I have tested my logins and they definitely are correct and also work on the external site for my HA. I was wondering if it was to do with my 2FA for my HA account (even though it worked in September) so I tried another account without 2FA and I still got an incorrect login error.
I was wondering if anyone knew if Google had changed anything or if there are now new steps I need to do to get my devices to show in Google Home again.
My HA config is:
google_assistant:
project_id: homeassistant-551f7
service_account: !include SERVICE_ACCOUNT.json
report_state: true
I’ve tried re-creating another project and following the tutorial again but still getting incorrect username and password. If anyone could help I would be soooooo grateful!!
Thanks for taking the time to read my post.
