Hi Guys, thanks for helping!
I run home assistant on a raspberry pi 4 and have the homewizard integration installed. Through this integration, I am able to add my homewizard energy socket succesfully. I also have a P1 meter that is seen by home assistant as a new device to be added. If I try to add this P1 meter, I get an error that the device cannot be reached.
Taken steps:
- Re-install homewizard integration
- Rebooting Home assistant
- reboot homewizard p1 meter
- Factory reset P1 meter
- Verify that ‘local API’ is enabled in the P1 settings in the homewizard app
None of these steps have worked. I would very much appreciate help since I want to build a dashboard that shows my energy consumption with relation to the outside temperature to see how well my house isolates under different temperature circumstances.
Once again, thanks a lot for your help!
