Unable to add Matter over Thread devices
Hello all -
Recently purchased an Aqara P2 Motion Sensor to add to my setup. I have an existing Thread network using a ZBT-1 and OTBR that has been working fine - connected to it are two Aqara T2 LED bulbs.
I have been unable to get HA to add the P2 sensor to this thread network on either iOS or Android. In order to test, I reset one of the light bulbs and now it also will not pair through the app.
It is clear the app connects to the devices over Bluetooth but appears to fail provisioning the Thread network. I have checked (and double and triple checked) that the Thread network credentials have been imported in the app. I get stuck at “Setting Up…” on iOS and now Android doesn’t even try to connect the device to a Thread network, it only offers Wifi - even though in the past it failed at checking network connection.
I am running HA0S 15.1, Core 2025.4.1, Supervisor 2025.03.4, Frontend 20250404.0, iOS 18.4 on an iPhone 15 Pro, and Android 12 on a Pixel 3.
Looking for some ideas to start chasing this down.
Thanks.
EDIT TO ADD - After fooling around more I finally got my LED bulb to pair again. Not sure I did anything differently. Trying to pair the P2 sensor right after still fails. The debugging logs show:
Matter pairing failed: Error Domain=com.apple.MatterSupport Code=1 “(null)”
