Unable to add Minimalist
I downloaded the minimalist frontend from HACS as per the instructions. I then add the integration as per the instructions but it says “failed to start”. I enable debugging and get this error code
"This error originated from a custom integration.
Logger: custom_components.ui_lovelace_minimalist.base
Source: custom_components/ui_lovelace_minimalist/base.py:434
integration: UI Lovelace Minimalist (documentation, issues)
First occurred: 10:47:17 PM (8 occurrences)
Last logged: 10:48:55 PM
‘dict’ object has no attribute ‘dashboards’"
So I follow the troubleshooting steps for this integration but to no avail. Resource never shows in my dashboards. At this point I’m just assuming it has very poor documentation. I have a very general install of HA so this should never even have been an issue, but atlas, here I am with a very easy to avoid situation had there been proper documentation for troubleshooting. I have never had an issue with anything else before. Anybody have the same issues? Is it just a crappy HACS frontend?
